Piston seized in block.?? - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 01-13-2017, 08:01 AM Thread Starter
Thanks (Given): 172
Likes (Given): 448
Likes (Received): 1026
Question Piston seized in block.??
Machine sat outside and has had water in it. What is best way to get it loose? I have loads of time to get it free. Just want to know the best method. It's an Italian made BCS tiller engine.
Thanks fellas!
This is something I have never had to deal with and all new to me.
post #2 of 26 Old 01-13-2017, 08:11 AM
Likes (Received): 66
Aluminum Block, hopefully without a Cast Iron Sleeve ?
Vermont007 is offline
post #3 of 26 Old 01-13-2017, 08:17 AM
Thanks (Received): 173
Likes (Given): 413
Likes (Received): 661
I would remove the head and go with the tried and true 50/50 mix of acetone and atf.
nwcove is offline
post #4 of 26 Old 01-13-2017, 08:20 AM
Snowbelt_subie's Avatar
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
ive heard people taking the spark plug out and using different things and letting them sit.
diesel fuel and mystery oil mix in the spark plug hole or just spray alot of pb blaster in the spark plug hole let it sit for a day or 2 then try to break loose with the crank bolt.
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
post #5 of 26 Old 01-13-2017, 08:37 AM
Elt31987's Avatar
Thanks (Given): 44
Thanks (Received): 14
Likes (Given): 235
Likes (Received): 47
Marvel Mystery Oil in the plug hole
2016 Ariens Deluxe 28 SHO AX306cc (921044) | Drift Cutters | Front Weight Kit | Handwarmers
1965 Ariens 10ML60D with 1970 10,000 Series Sno-Thro Attachment 10995 | Tecumseh H70-130216G (7HP)
2016 Ariens Razor SP Mower AC159cc (911175)
2016 Predator 8750 Peak/7000 Running Watt Generator 13HP 420cc (69671)
Elt31987 is offline
post #6 of 26 Old 01-13-2017, 09:17 AM
Thanks (Received): 112
Likes (Received): 298
Thanks fellas!
Is it a two stroke or a 4 stroke?
Work fascinates me.
skutflut is offline
post #7 of 26 Old 01-13-2017, 09:39 AM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
I never tried marvel mixed with diesel but ATF and acetone is very effective.
drmerdp is offline
post #8 of 26 Old 01-13-2017, 10:31 AM
Likes (Received): 42
Marvel in the plug hole for 72 hours should free it up. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #9 of 26 Old 01-13-2017, 05:33 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
GAfternoon, When you say "Get it Free", are you trying to save this engine and parts? If not, an air hammer with a chisel bit is pretty effective. If you are, taking the cylinder head off and using the acetone/ATF mixture may be the best bet. Fill the cylinder and let it set up for a few days. Then try tapping the piston with a block of wood, while trying to turn the crankshaft. GLuck, J
JayzAuto1 is offline
Likes King285 liked this post
post #10 of 26 Old 01-13-2017, 05:41 PM
Likes (Given): 467
Likes (Received): 483
Acetone and ATF or Marvel mystery oil, fill the cylinder and let it sit for a few days before trying to free it up.
