Back fire on b&s 250 cc polar force engine - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 01-15-2017, 03:51 PM Thread Starter
Hi I have noticed on my Ariens deluxe 28 when the engine is warm and I go to shut the engine down and I slide the throttle control from fast to slow the engine has a subtle backfire, if I slide the throttle slowly there is no backfire. The engine runs good no choke when warm, checked valve adj ok. I don't think that this is normal. Does anyone have any ideas. thanks for your help.
2013 ARIENS DELUXE 28 921022 BRIGGS 11.50 Heated grips, 2 LED lights, armorskid plates, Impeller kit,Mini hour tach meter, Drift cutters, Tire chains
CRAFTSMAN 5HP 22IN TECUMSEH HS50-67195D
malone is offline
post #2 of 6 Old 01-15-2017, 04:46 PM
Thanks (Received): 98
Likes (Received): 260
You should slowly lower the throttle all of the time. What you are seeing is normal with today's carb settings.
RIT333 is online now
Likes 43128 liked this post
post #3 of 6 Old 01-15-2017, 05:08 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
Nothing to worry about, I've had this happen on 4 of the B&S snow series engines I've worked on. Normal. It will even do it sometimes when reducing the throttle slowly, but not always.
GoBlowSnow is offline
post #4 of 6 Old 01-15-2017, 05:38 PM
thats normal, almost every engine does it
post #5 of 6 Old 01-15-2017, 11:13 PM Thread Starter
thanks i'm still learning about small engines
malone is offline
post #6 of 6 Old 01-16-2017, 08:51 AM
Likes (Received): 27
Cool
IMO this could be from carbon deposits. Run some Sea Foam through it and see if it helps. Can't hurt and will clean the fuel system also.
Let It Snow
Toro 928 HD OHXE
mrfixit is offline
