2013 Ariens eaing friction wheels - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-20-2017, 10:44 AM Thread Starter
Thanks (Given): 9
Hi Guys
My Ariens platinum 30 is eating friction wheels like crazy.
New one last year(i bought it second hand last year) replaced worn friction wheel and this year have to replace again after a total of a dozen storms.A friction wheel should last for years if all is normal.The friction material is laying on the bottom pan like shredded cheese.I adjusted the gap and spring tension as per manual.The plate the friction wheel runs on seems in good shape
Anybody have any ideas,i would appreciate a hand.
Thanks!
flattop is offline
post #2 of 8 Old 01-20-2017, 10:49 AM
Likes (Given): 35
Likes (Received): 15
I don't really *know* exactly, but it seems to me that there are three possible causes.
1: The wheel is pressing too hard on the plate, causing undue friction
2: The wheel is too far forward or backward, causing sideways motion to eat away at it
3: The wheel is at an angle (this seems less likely, the angle would probably have to quite noticeable)
That's all I got
JD in NJ is offline
Thanks flattop thanked for this post
Likes toroused liked this post
post #3 of 8 Old 01-20-2017, 11:07 AM
Thanks (Received): 195
Likes (Received): 816
What is the Condition of the drive Plate? If it is scored badly, that could cause undue wear on the Friction Wheel.
Jackmels is offline
post #4 of 8 Old 01-20-2017, 11:25 AM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
Are the bearings good on both ends of the shaft that the rubber disc is on? Is the disc carrier assembly tight, and alined. ?
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is online now
post #5 of 8 Old 01-20-2017, 02:40 PM Thread Starter
Thanks (Given): 9
Thanks guys I'll check all those things and put the new wheel on.
flattop is offline
post #6 of 8 Old 01-20-2017, 04:57 PM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
Are you running the machine on Gravel ??
Do you have many times the machine stops moving or throwing even when you have the handles all the way down ??
You mentioned the drive disc was in good shape, is it nice and flat and smooth to the touch ?? Any signs on the drive plate of the rubber ground into it or burning ??
post #7 of 8 Old 01-20-2017, 06:37 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
My experience is its adjusted too tight, after the loss of the first rubber the plate gets chewed up and contributes more to eating more rubber.
-efisher-
e.fisher26 is online now
post #8 of 8 Old 01-21-2017, 03:16 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Do you have pix of the "Shredded Cheese" laying at the bottom of the pan? Your not trying to change gears while in motion, are you?? Jay
JayzAuto1 is offline
