loose wheel on shaft - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-22-2017, 02:18 PM Thread Starter
My snowblower has a lot of play in the wheels. When I slide the wheel assembly on to the axle shaft, there is a lot of slop. Any idea what I need to do to fix it?
maxwell_smart007 is offline
Likes Sid liked this post
post #2 of 12 Old 01-22-2017, 05:21 PM
Thanks (Received): 97
Likes (Received): 259
Are you saying that the axle is moving, or the I.D. of the wheel is bigger than the O.D. of the axle ? If the 2nd, then either your wheels have worn, or the axle has worn, and one needs to be replaced. If the axle is moving, then you need to put the S.B. in the service position, and remove the lower cover and either take some pictures and post, or do some inspection/diagnosis yourself.
Either case is not good !
PS - I.D. = Inside Diameter and O.D. is Outside Diameter, S.B. = Snow Blower
RIT333 is online now
post #3 of 12 Old 01-22-2017, 05:33 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 663
it may be of help to mention the make and model
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 12 Old 01-22-2017, 05:53 PM
Thanks (Received): 212
Likes (Received): 767
Remember that Kenny Roger's song......You picked a fine time to leave me Loose Wheel.........
cranman is offline
Likes Grunt liked this post
post #5 of 12 Old 01-22-2017, 05:58 PM
Likes (Given): 414
......with four hundred children and a crop in the field.....
28 " Ariens Sno Tek
Toro CCR ss
post #6 of 12 Old 01-22-2017, 06:21 PM
I suspect the OP is referencing sloppy bushings around the axles as they enter the Housing.
Vermont007 is offline
post #7 of 12 Old 01-22-2017, 06:56 PM
Likes (Given): 414
...or , depending on the machine, one or both wheels might be pinned in the wrong hole, that will create tons of horizontal " slop". more info from the op is needed.
28 " Ariens Sno Tek
Toro CCR ss
post #8 of 12 Old 01-22-2017, 08:04 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Love your sense of humor guys.... I'll fit right in here
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #9 of 12 Old 01-23-2017, 12:58 PM
Thanks (Received): 14
Likes (Received): 65
Hmm, how did that change from "four hungry children" to "four hundred children"?
And that's the original "Lucille" song. Here are the lyrics to the parody "loose wheel" version for your reading enjoyment:
Loose Wheel, Parody Song Lyrics of Kenny Rogers, "Lucille"
guyl is offline
Likes Grunt, cranman liked this post
post #10 of 12 Old 01-23-2017, 01:08 PM
" 'scuse me while I kiss this guy " Hendrix
"There's a bathroom on the right" CCR
