Auger gearbox swap - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-22-2017, 05:58 PM Thread Starter
Thanks (Received): 212
Likes (Received): 767
Auger gearbox swap
OK guys.....I know someone here must have tried this and can save me some work. Has anyone ever tried to swap a 10000 series gearbox for a 924 series?....or mount an older bucket assembly on the newer tractor? I want to try.....
cranman is offline
post #2 of 8 Old 01-22-2017, 06:13 PM
Thanks (Received): 195
Likes (Received): 816
10000 series Does Not Fit. IIRC, an early 924 with cast iron gearbox will bolt to ST Series.
Jackmels is online now
Thanks cranman thanked for this post
post #3 of 8 Old 01-22-2017, 07:47 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Hey Cranman, I modified one for a friend. Just had to move the 4 mounting tabs up exactly 1", in my pixx i had a 10HP chassis from a ST 1032 i was rebuilding. What you need to be sure of is which model / style gearbox your swapping, older ones have splines for the clutch dog to slide on and newer ones like Jackmels suggested as it will have just a plain shaft for the pulley to mount to. Also had to remove the lower belt guard that was mounted to the chassis.
PS.... Can anybody explain why the forum rotates my uploaded pixx. Thankxx
ID:	97737   Click image for larger version
ID:	97745   Click image for larger version
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #4 of 8 Old 01-23-2017, 01:19 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Cranman, as Shaw pointed out, anything can be done, IF you have: the tools, knowledge, experience, money, desire and ambition. But just because you can, doesn't mean you should. It can be fun, exciting and you will have a tremendous sense of accomplishment. But you can never get the money OR time you invest in that back. Very frustrating..... I know, I've tried. I graduated from the School of Hard Knocks, with a Phd and Busted Knuckles. GLuck, Jay
JayzAuto1 is offline
post #5 of 8 Old 01-23-2017, 10:11 AM
Thanks (Given): 40
Likes (Given): 48
Originally Posted by jayzauto1 View Post
cranman, as shaw pointed out, anything can be done, if you have: The tools, knowledge, experience, money, desire and ambition. But just because you can, doesn't mean you should. It can be fun, exciting and you will have a tremendous sense of accomplishment. But you can never get the money or time you invest in that back. Very frustrating..... I know, i've tried. I graduated from the school of hard knocks, with a phd and busted knuckles. Gluck, jay
Ditto !!
~~ And Lastly ~~
post #6 of 8 Old 01-23-2017, 04:06 PM Thread Starter
Thanks Shaw and Jay...I haven't got to the point of trying the older bucket on the 8-24, but they seem to be very similar. Not a big deal to put a pulley over the splines on the older bucket.....I've got other projects ahead of me right now, but it doesn't look that hard...nice job on that welding Shaw....My motto as I've aged is " if something is difficult......it's just not worth doing" Homer Simpson.
cranman is offline
post #7 of 8 Old 01-23-2017, 04:09 PM
Here's a ST with Early 924 Auger. This one is a Frankenstein, ST724, 8hp engine, and 924 auger with cast iron gearbox. Upon first inspection, PO had carb linkage set up wrong.
Likes cranman liked this post
post #8 of 8 Old 01-23-2017, 04:34 PM Thread Starter
It has a really nice look to it Jack.....
cranman is offline
