Cant get John Deere 828D to start, help appreciated. - Snowblower Forum : Snow Blower Forums
post #1 of 28 Old 01-27-2017, 03:58 PM Thread Starter
Hi All,
So I've just been fortunate to get a JD 828D machine free of charge!
Its not been used since last winter and was stored without any gas in it. Ive cleaned it up and it looks as good as new, just needed 2 new tires on which i picked up from Amazon.
Ive been trying to start it but not having much luck. I'm getting a good spark and gas is getting TO the carb but its just not firing up. I believe its the Tecumseh engine and have had a look around youtube and online but to no avail.
Would appreciate any help in trying to trouble shoot it
fcat is offline
post #2 of 28 Old 01-27-2017, 04:14 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 418
Likes (Received): 664
wow....that is clean ! have you tried a shot of starting fluid in the intake to see if it will make a kick to go ?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 28 Old 01-27-2017, 04:28 PM
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
If it has good spark most likely carb.
That is a nice ariens painted green
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #4 of 28 Old 01-27-2017, 04:33 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
to SBF fcat
I'd go for a small squirt of starting fluid to see if she pops.
When you pull it over does it feel like there's good compression ??
post #5 of 28 Old 01-27-2017, 04:34 PM Thread Starter
Thanks for the replies, haven't tried starting fluid, can i just remove the carb and fire a bit of gas in the intake or should i get a can of starting fluid ?
I was tempted to just order a new carb on Amazon for 15 bucks and just replace it anyways.
fcat is offline
post #6 of 28 Old 01-27-2017, 04:39 PM Thread Starter
to SBF fcat
Thanks for the welcome yeah when i pull the manual cord there's definitely compression
fcat is offline
post #7 of 28 Old 01-27-2017, 04:44 PM
Thanks (Given): 589
Likes (Given): 4358
I'd look in the throat of the carb and make sure the throttle plate is opening as you open the throttle, set the throttle to hi, choke off/open, splash a little gas in the throat and close the choke and see if she fires up.
Always nice to have a can of starting fluid around and a bit easier and safer than trying to splash gas sideways into the throat but you gotta do what you gotta do.
post #8 of 28 Old 01-27-2017, 04:50 PM
Thanks (Given): 82
Likes (Given): 418
if you go the splash of gas route ( a bit dangerous), i have had luck carefully putting a teaspoon or so directly in the plug hole, that was the only way my old 10.5 hp tech would start at the beginning of every season, was always fine after that.
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 28 Old 01-27-2017, 04:51 PM
Likes (Given): 53
I don't think I would trust a carb for $15. Also check fuel lines even and the primer line as well .
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #10 of 28 Old 01-27-2017, 04:53 PM Thread Starter
I just ordered a new carb from amazon, couldn't not do for 15 bucks! Gonna go get some starting fluid first thing in the morning and get this thing running i can always return the card to Amazon if the existing one just needs cleaning.
Quick question, the key switch on it, it has a single wire to it, Im getting a spark whether the key is turned to the right or the left, is this correct ? is it just a kill switch and ground something out to cut it out ?
fcat is offline
