clogging issues and speed throwing - plastic chutes vs metal chutes - Snowblower Forum : Snow Blower Forums
View Poll Results: Metal chutes or Plastic chutes throw further and clogs less
Plastic chutes throw further than Metal 0 0%
Metal chutes throw further than Plastic 3 30.00%
Plastic chutes throw further and clog less than Metal 2 20.00%
Metal chutes throw further and clog less than Plastic 0 0%
I have no idea 5 50.00%
Voters: 10. You may not vote on this poll
post #1 of 9 Old 01-29-2017, 11:59 AM Thread Starter
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
It's been discussed on here how to throw further by using a rubber impeller kit so there is less clogging of the chute. There's been talk of lining the chute with film or plastic to reduce friction. Talk that you can spray the inside of the chute with PAM, an aerosol cooking oil spray; Pledge, an aerosol furniture polish; or a spray car wax detailer. There's been discussion a longer chute will throw snow further than a shorter chute thus I would think a longer chute would have less clogging
All MY snowblowers have metal chutes except for several I picked up to sell after going through them but I am waiting for it to snow! But I am in a part of central New Jersey that does not get a lot of snow - light or deep, and it does not snow often enough for me to make comparisons.
Which chute clogs less, and throws the snow further, plastic or metal?
Likes Prime liked this post
post #2 of 9 Old 01-29-2017, 12:09 PM
Likes (Received): 11
There is more to throwing distance than chute material.
Impeller speed, snow density, snow volume in impeller, Dia. of impeller, size of discharge opening, .....
BeerGhost is offline
post #3 of 9 Old 01-29-2017, 12:22 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
IMO, and impeller kit, and a long shute (plastic or metal) will be best, a longer shute will have more (i may not have the correct term on this) centripetal force, forcing snow up and out of the shute. The longer the shute the more force built up.
-efisher-
e.fisher26 is online now
post #4 of 9 Old 01-29-2017, 12:33 PM
Thanks (Received): 98
Likes (Received): 260
-efisher-
I would think that the longer the shoot, the more friction that your snow hits, and it impedes the distance. The diameter of the impeller is what creates the centripetal force - longer makes for force - i.e.higher tip speed.
RIT333 is online now
post #5 of 9 Old 01-29-2017, 01:24 PM
Likes (Given): 44
Could be, I don't know what would be more, the friction or the force
post #6 of 9 Old 01-29-2017, 01:41 PM
Design of the impeller: How much snow will it grab n throw
Torque to throw the snow where it came from.
Horsepower so you can throw the snow where it came from faster.
Someone is getting ready for the snowblower races!
post #7 of 9 Old 01-29-2017, 05:33 PM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
I personally think that taller chutes help to collect and form the snow into a well packed and organized stream. This regulated stream of snow travels farther do to the lack of turbulance. Obviously the impeller speed and output flow matters tremendously as well.
I had an old toro 3521 that i modified with a 212 predator engine and taller chute off a newer toro. The taller chute made a very noticeable difference in the flow pattern and throwing distance.
I think then chutes geometry is more important the the material its manufactured from.
drmerdp is offline
Likes Town liked this post
post #8 of 9 Old 01-29-2017, 05:54 PM
Thanks (Given): 28
Thanks (Received): 25
Likes (Given): 180
Likes (Received): 41
+1 on that. Agree 100% there are more factors in play than the chute. Rarely have the same snow conditions twice in a row. Conditions can change in hours in the same storm. The variables are constantly changing.
Prime is offline
post #9 of 9 Old 01-29-2017, 05:58 PM
Thanks (Given): 69
Thanks (Received): 123
Likes (Given): 116
Likes (Received): 157
I agree. The taller chutes have a smooth curve that helps achieve the longer distances. In my urban environment the actual throwing distance is not as important as the ability to direct the flow. It would be great to have a smooth shape for the deflector so snow could be blown into the wind without being slowed down. A shape that goes beyond the dual stage deflector on Honda and Yamaha machines.
Town is online now
