Axle bushing - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-31-2017, 08:10 AM Thread Starter
Axle bushing
after adjusting the shoes on my MTD i noticed their was an odd tilt like a desk without a piece of paper under it. I pulled the axle bushing and its some what egg shaped I'm going to replace it but just wanted some opinions on whether that would be the issue?
Sammyboy is offline
post #2 of 7 Old 01-31-2017, 08:24 AM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
If it's just a plastic spacer to hold shaft off the frame, it happens, keep them greased.
e.fisher26 is online now
post #3 of 7 Old 01-31-2017, 09:10 AM
i,n my experience those only last 5 years with average use. those are the hexagonal shaped black plastic bushings right?
post #4 of 7 Old 01-31-2017, 09:23 PM Thread Starter
yea they look pretty cheap.
Sammyboy is offline
post #5 of 7 Old 02-01-2017, 06:48 AM
Likes (Received): 66
Inexpensive, yes; but without lubrication, you may find that these plastic bushings wear more slowly than the steel axle rotating inside them. A couple drops of oil or grease will delay any wear. I use a salt resistant "Marine Grease" on my snowblower.
Vermont007 is offline
post #6 of 7 Old 02-01-2017, 07:18 AM
Likes (Received): 345
I put a thread on the forum over a year ago on how to convert the axel and auger plastic bushings to flanged roller bearings.
https://www.snowblowerforum.com/forum...-bearings.html
It was well worth the effort. On the 10 HP I converted, if you tip the front up off the ground you can move the unit without power easily with 1 hand.
Take a look, may be something of interest for you.
HCBPH is offline
Likes Mike C. liked this post
post #7 of 7 Old 02-01-2017, 10:47 PM Thread Starter
thanks guys appreciate it.
Sammyboy is offline
