Tecumseh 4HP carb - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-07-2017, 08:01 PM Thread Starter
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
Tecumseh 4HP carb
Needing to get a new carb for a 4HP and trying to get it going before this storm hits, I DO have a adjustable carb for a 5HP. Does anyone know if they use the same carb, even if jets would be different I have a adjustable so I can tune it, just not sure if it has the same mounting bolts and too late to pull it tonight to find out so I figured I would ask.
Dauntae is offline
post #2 of 6 Old 02-07-2017, 09:29 PM
e.fisher26's Avatar
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
I believe its 3-5, 6-9, 10-12hp and so on. Are all linkages the same on both?
-efisher-
e.fisher26 is online now
post #3 of 6 Old 02-07-2017, 09:41 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Yes, close enough for an upcoming storm. As long as the 5hp is a Tecumseh and not Briggs
GLuck, J
JayzAuto1 is offline
post #4 of 6 Old 02-07-2017, 09:49 PM Thread Starter
Thanks (Given): 13
Likes (Given): 147
So far it seems EVERYTHING I find to buy has a Tecumseh on it, wood chipper, Yard vacuum for the girlfriend, 8 snow blowers currently at my house..... even the 2 stroke snow blower, At least a few are leaving real soon. Once I switch the carb on the Ariens 420 it's getting picked up tomorrow, The ariens 2 stroke, new carb and belt came in so should have that done and gone in less than a hours work. Thank you for the fast responce, I will put my carb on the 420 and order another for the engine I got it for. Big snow coming so gotta get these things done and delivered.
as for the linkages, yes they are the same, Only thing I thought strange is the bowl seemed smaller but I did not compare it to the others, But will make sure all matches tomorrow, It runs good but can't turn choke off and o-rings are all splitting thus I think air leaks so the reason it needs the choke. Brass float also and that will fail sooner or later so rather a new carb than change the o-ring for the price.
Dauntae is offline
post #5 of 6 Old 02-07-2017, 09:59 PM
e.fisher26's Avatar
Likes (Given): 44
Ebay replacment carbs are awsome for the price, ive bought a few with no issues
-efisher-
Likes 43128 liked this post
post #6 of 6 Old 02-07-2017, 10:05 PM Thread Starter
Thanks (Given): 13
Likes (Given): 147
OH they are, You should have seen my excitement when I discovered they sell "adjustable needle" carbs for the tecumseh engines, It's all I order now, Still have 2 fixed jet ones also on the shelf but I'll find use for them.
Dauntae is offline
