Ariens-910002 No Reverse - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 02-08-2017, 08:31 AM Thread Starter
Hi All,
Been a great winter so far and I couldn't be happier with the way my Ariens-910002 has been preforming. Just got back from vacation and it never fails that it would snow..... Took the old blower out today and all of a sudden I had no reverse. Not sure if it is a problem with the lever it self or a problem with the internal mechanism. Does anyone have any diagrams of the way the mechanism are supposed to look or any information that they can lead me too would be appreciated.
Dustin
2005 MTD Yard Machine 26inch-8hp
1971 Arines-Sno-Thro-24in-7hp
2001 Craftsman-22"-5hp
dhoyt714 is offline
post #2 of 11 Old 02-08-2017, 08:39 AM
tarring's Avatar
might be a little lube problem.
tarring is offline
post #3 of 11 Old 02-08-2017, 10:55 AM
Thanks (Given): 172
Thanks (Received): 307
Likes (Given): 447
Likes (Received): 1023
https://www.youtube.com/watch?v=Zvp5pvlc_f4
+1 on the lube. It may be a possibility that you need to adjust your shift linkage.
micah68kj is offline
post #4 of 11 Old 02-08-2017, 10:59 AM
Thanks (Received): 112
Likes (Received): 297
Does your shift lever move easily, or is it stiff and sticky? How about your forward speeds? Are they normal and working as designed, or does 1st gear seem to move a too fast? Any loose adjustment bolts on the shift linkage?
Work fascinates me.
skutflut is offline
post #5 of 11 Old 02-08-2017, 04:21 PM Thread Starter
I tried lubing it up with no change. The forward gears all work as designed. Its just so tough it doesn't want to pull back from neutral. There seems to be some play on the linkages where the cotter pins go in. Iam going to try to replace them and see what happens.
dhoyt714 is offline
post #6 of 11 Old 02-08-2017, 05:46 PM Thread Starter
Replaced the cotter pins and no luck. No matter how hard I pull i cant get it to move. Its like something that is supposed to be assisting it has stopped working.
dhoyt714 is offline
post #7 of 11 Old 02-08-2017, 06:37 PM
Thanks (Received): 212
Likes (Received): 767
Simple concept....reverse is on the other side of the disc......look and see what is keeping the drive wheel from moving over. Maybe adjust the gear shift.
cranman is offline
post #8 of 11 Old 02-08-2017, 07:03 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
Double Clutch it as You shift it in Reverse.
Jackmels is offline
Likes JayzAuto1 liked this post
post #9 of 11 Old 02-08-2017, 07:10 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 191
Dhoy724 where in NH you located?? Im in MA near the Hudson NH border, i can help you with this problem at my shop. Probably have whatever you need in the way of parts. Im guessing it's adjustment or a rusty shaft that the drive slides upon. Can do it tonight if you have a means of transportation. Shoot me a PM with contact Info.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #10 of 11 Old 02-08-2017, 07:41 PM Thread Starter
Thanks everyone for the help. I didn't realize that the clutch linkage slipped down preventing the lever from moving up or down. She's all ready for the big storm tomorrow!
Dustin
dhoyt714 is offline
