I need help identifying Make and shear bolt issue - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-16-2018, 06:13 PM Thread Starter
So, this all starting a few days ago when the snowblower my dad gave me (was bought new by my grandfather in 1988 ish?) blew a shear bolt.
So, Ive been googling and searching and everything the last 3 days looking for more info on my blower.
All I had was that my dad thought it mightve come from Sears back then, and that he wasnt sure.
I found the ID tag but all that was visible was the address 155 Orenda Road Brampton, after some searching I found out that was Nomas old stomping grounds..........
I went out with a black marker hoping that the serial and model was stamped in and I could bring them up...
I did, the tag says
SC522
Snow Commander
96069
It looks like a Noma Grand Prix and Estate (with the exception of the throttle control on the part with the engagement lever for the auger)
So now that I know what the tag says its even harder to find info on it.
Tried, Noma, Craftsman, Canadiana, Murray, Mastercraft......nothing.
If it is a Noma it doesnt have the one side bigger then the other shear pin........Ive taken off the one that was still intact but I cant see the broken one for the life of me.
Any help at all would be greatly greatly appreciated.
nfstyl is offline
post #2 of 10 Old 01-16-2018, 06:15 PM Thread Starter
Here is a picture of the tag
nfstyl is offline
post #3 of 10 Old 01-16-2018, 06:37 PM
Likes (Received): 303
liyuhvfkutg
post #4 of 10 Old 01-16-2018, 07:17 PM Thread Starter
She's not the prettiest girl at the party, but she starts on the first pull 98 percent of the time.
ID:	125842   Click image for larger version
ID:	125850   Click image for larger version
ID:	125858   Click image for larger version
ID:	125866   Click image for larger version
nfstyl is offline
post #5 of 10 Old 01-16-2018, 10:20 PM
Money_man's Avatar
She looks like a beast
Money_man is offline
post #6 of 10 Old 01-16-2018, 10:48 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
You don't need the model number to find the shear pins.
The only thing you need is the diameter of the hole, and the length, then you can match it up. The hole probably is 1/4", then you only need the length. Type the size into Amazon, you'll find it.
JLawrence08648 is offline
post #7 of 10 Old 01-18-2018, 05:01 PM Thread Starter
Replacement bolts acquired.
Now I just need to get the one that broke off in the axle out.
Anyone have any thoughts on the make of this thing?
I'm hoping to get some replacement parts and spending some time repairing and painting this thing over the summer.
nfstyl is offline
post #8 of 10 Old 01-18-2018, 05:22 PM
Thanks (Given): 78
Thanks (Received): 161
Likes (Given): 404
Likes (Received): 641
sure looks like a noma (AMF,Canadiana,Dynamark,Sears) to me.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 10 Old 01-18-2018, 08:56 PM
Thanks (Given): 146
Thanks (Received): 325
Likes (Given): 431
Likes (Received): 783
Slick thinking with black marker on the tag, to make it legible.
For getting the shear bolt out, I've rotated the augers on the shaft until I'm lined up with the hole, and can see the whole face of the shear bolt. Then I used a round punch, and a mallet, and drove it out.
One time I had one that was somewhat bent, and did not want to come out of the hole. I used a Dremel to grind off one end of the bolt, until I could get it out with the punch.
post #10 of 10 Old 01-23-2018, 09:22 PM Thread Starter
Thanks. I guess spying on all those cheating girlfriends writing notes in high school paid off.
Finally got the bolt out after dremeling and grinding.
nfstyl is offline
