Toro power max 826 le - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-17-2018, 08:25 AM Thread Starter
Hello everyone. I recently was given a basically brand new snowblower. Itís about 9 years old , used couple of times. Last time was likely 8 years ago. Whatís the best method to get this running.
Gas line was open , not sure if it had gas when put in storage.
Thanks a lot !
Sf49168 is offline
post #2 of 13 Old 01-17-2018, 09:11 AM
Thanks (Received): 96
Likes (Given): 39
I would start with changing the oil, then put some fresh gas in it and give it a go, with the electric starter. When it doesn't start, then I might try some starting ether and see if it fires - which it probably will. If it continues to run after the ether is burned off (maybe 5 seconds), then you are good to go. Otherwise, you will have to clean the passages in the carb. I gave you Snowblower 101, cleaningt he carb is Snowblower 301. You may have to check out some videos from Donyboy on YouTube, or just buy a Chinese carb.
Good luck, and report back.
RIT333 is online now
post #3 of 13 Old 01-17-2018, 09:32 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
In addition to the oil change, i'd remove the spark plug and get a little bit of oil in the top of cylinder. Spin the engine a few times with the pull cord.
Put it all back together, add a good amount of carb/injector cleaner to the fuel tank and see if you can get it running.
Great find/gift.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is online now
post #4 of 13 Old 01-17-2018, 12:35 PM Thread Starter
Thanks everyone. My plan was to change fluids and spark plug etc. I was told maybe use true fuel and see if that helps with process.
Defenitly a great find. Good think my wifeís 91 year old grandmother is very nice
Will post back when I get this going. Luckily Ny weather will be warm this weekend to work on it
Sf49168 is offline
post #5 of 13 Old 01-17-2018, 02:06 PM
Thanks (Given): 229
Thanks (Received): 198
Likes (Given): 2030
Likes (Received): 515
Nice find indeed! Keep us posted!
('87 Toro 38150 826)
classiccat is online now
Likes Mike C. liked this post
post #6 of 13 Old 01-18-2018, 12:58 PM
Thanks (Received): 29
Likes (Received): 41
First thing I would do is pull the flywheel cover off and check for a nest. Make sure to check behind the flywheel also.
351beno is offline
Likes jtclays, Mike C., classiccat liked this post
post #7 of 13 Old 01-18-2018, 01:18 PM
Likes (Received): 303
fgfygj
Name:	tecumseh recoil shroud packed 006.jpg
post #8 of 13 Old 01-21-2018, 12:43 PM Thread Starter
So I changed all the fluids and spark plug, tried and nothing
Added some starting fluid to it and it sounds like it wanted to start but wouldnít last more than 2 seconds.
Next up is pull carb apart and clean good. Worst case will have to get a new carb but they arenít that much.
Sf49168 is offline
post #9 of 13 Old 01-21-2018, 12:58 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Likes (Received): 290
new carbs can be had for that Tecumseh for $10-$15, Best would be to get one with adjustable needles if you need to get a carb but odds are it's just a plugged jet and no new carb needed.
Dauntae is online now
post #10 of 13 Old 01-21-2018, 01:18 PM Thread Starter
Cleaned jet in screw of bowl plug , left carb on blower and dosed with cleaner.
Started and it fired.
Been rough idle since it started 2-3 mins but maybe cause itís been sitting so long ?
Sf49168 is offline
