Small Engine Tachometer recommendations? - Snowblower Forum : Snow Blower Forums
post #1 of 44 Old 01-17-2018, 05:58 PM Thread Starter
SayItAintSnow's Avatar
Thanks (Given): 24
Thanks (Received): 30
Likes (Given): 45
Likes (Received): 138
Question Small Engine Tachometer recommendations?
As I read through many posts on this board, I notice that quite often that more experienced members than myself, stress the importance of our machines revving at the right top speed, in order to insure proper throwing distance. Makes perfect sense of course.
Recently, I thought I'd grab a small engine tach, figuring that it would be useful for my other power equipment as well.
I can see there's a lot choices out there, but like anything else, there's probably some devices that are better than others in terms of accuracy. Just as is the case with other diagnostic tools (compression gauges, spark indicators, etc.) I'm sure there are some tachs out there that are pure junk. Much like an unreliable compression gauge, getting a substantially wrong reading of engine speed, and making adjustments accordingly, in my opinion is worse than not having any reading, and leaving well enough alone.....
Any recommendations about small engine tachs? Best type? Wireless, optical, inductive coupled?
Any advice would be greatly appreciated. Thanks!
--- Clint Eastwood
SayItAintSnow is offline
post #2 of 44 Old 01-17-2018, 06:04 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
i got an ebay tach/hour meter. it picks up the spark signal from the spark plug wire. induction.
it uses a lithium replaceble battery cr2450, works fine even in the cold. is it accurate? id say yes as it changes w/revs and at max throttle it reads at roughly 3600rpm, which is spec for a tecumseh 10hp flathead.
u can see it working in this vid of mine, its mounted temporarily and some electrical tape is covering the screen. i have since permanently mounted it to the control deck.
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #3 of 44 Old 01-17-2018, 06:06 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
I'm reviewing old posts on this right now. I did a search for "tach".
The Vibratach has been around for 40 years but I don't know the accuracy of it.
The point and shoot tachs require a mark on something spinning, flywheel, crankshaft, or crank pulley to measure the true engine rpms. Similar to a timing light used on cars. I believe the mark can be tape, paint, chalk, magic marker.
JLawrence08648 is offline
post #4 of 44 Old 01-17-2018, 06:06 PM
Likes (Received): 8
I've only used cheap optical handheld type units, I use it for a lot of different RPM measurement needs with no problem. I don't know about the accuracy, but it's good enough for me.
1998 Honda HS621, 1990 Toro 521
EdwardC is offline
post #5 of 44 Old 01-17-2018, 06:12 PM
Thanks (Given): 229
Thanks (Received): 199
Likes (Given): 2031
Likes (Received): 516
I keep a hardline tach/hourmeter mounted permanently on my keeper machines.
('87 Toro 38150 826)
classiccat is online now
post #6 of 44 Old 01-17-2018, 07:33 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
I have a Sandec, pretty happy with it so far.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #7 of 44 Old 01-17-2018, 07:54 PM
ourkid2000's Avatar
https://www.youtube.com/watch?v=xb52J9uapl8&t
Vinnycom, I use the same tach. You sure you can replace that battery? Mine looks completely sealed. Works well otherwise
Current machines:
2016 Toro PowerMax HD 928 OHXE
2004 Toro CCR 3650
2003 Toro CCR Powerlite 3.5 HP
ourkid2000 is offline
post #8 of 44 Old 01-17-2018, 07:54 PM
Thanks (Given): 146
Thanks (Received): 325
Likes (Given): 430
Likes (Received): 780
I have several of the inductive type of tachometers/hour meters. Most of mine are the inexpensive ~$10 eBay ones. None of mine allow replacing the batteries that I know of, however. That would be a nice feature.
vinnycom, do you have a link to the one you bought?
I've bought 2 of these, for the machines where I wanted a slightly better unit. Hardline Products HR-8061-2. It works for 1- or 2-cylinder engines, up to 16,000 RPM. That may sound useless, but it allows checking chainsaw RPMs as well (some saws have suggested tuning the carb based on RPM with no load, typically >10,000 RPM):
I haven't seen signs of RPM inaccuracy in the ones that have allowed checking that (when used with my generators, where I can compare against the frequency shown on my Kill-A-Watt, for instance).
The optical type sound handy (nothing installed on the machine), but you need a clear view of something like the flywheel to use them. The inductive are very easy to install (just wrap the wire around the spark plug wire), and also permit monitoring RPM during use, as well as giving you an hour meter. The hour meter can be nice to get a sense of how much time you have on your oil, etc.
post #9 of 44 Old 01-17-2018, 07:58 PM
vinnycom's Avatar
Thanks (Given): 59
Likes (Given): 58
mine is replaceble, but there are ones that are not, it usually states so in the listing info. i bought a cr2450 only too find one already installed, but was missing the rubber gasket on the battery cover, so i just used gorilla black duct tape to cover up the battery cover area
vinnycom is offline
post #10 of 44 Old 01-17-2018, 08:04 PM
Thanks (Received): 96
Likes (Given): 39
With some prying, the bottom panel can be opened up, and the battery can then be replaced - even on the non-replaceable ones. I was successful with mine.
RIT333 is online now
