Any one figure out install throttle control on a Predator? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-24-2018, 01:10 PM Thread Starter
Thanks (Given): 92
Thanks (Received): 183
Likes (Given): 70
Likes (Received): 421
I don't own a Predator but will be purchasing one for a 5/24" Noma that I've decided to keep, selling my Ariens 5/22" ST522.
So I've never have had the opportunity to take the carb cover off a Predator to look at it.
Is there a way to install a throttle control to be able to throttle down or idle a Predator?
post #2 of 9 Old 01-24-2018, 01:17 PM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 294
Attached to the throttle lever is a wire clamp and retaining strap for any old throttle cable.
drmerdp is offline
Thanks JLawrence08648 thanked for this post
post #3 of 9 Old 01-24-2018, 01:20 PM
deezlfan's Avatar
Likes (Received): 30
Yes, the provisions are already there to install a cable. It's just sort of hidden a bit by the air cleaner housing but can be seen looking straight down on the engine. I didn't bother but it's personal preference.
There's just one thing I'll guarantee , the best things in life, they sure AIN'T FREE !!
88 Craftsman II Trac-Plus 10/32 [wheeled conversion]
71 Ariens SnoThro 6/24 [Predator 6.5 repower]
72 Ariens SnoThro 6/24 with original Tecumseh H60
7? Ariens Tractor with rotary mower attachment [Tecumseh HSK100 repower]
deezlfan is offline
post #4 of 9 Old 01-24-2018, 04:03 PM
Thanks (Given): 75
Thanks (Received): 186
Likes (Given): 65
Likes (Received): 647
I've done it on cranberry harvest equipment because they use a cyntrifugal clutch...easy. I don't bother with snowblowers.
cranman is online now
post #5 of 9 Old 01-25-2018, 08:13 AM
Thanks (Received): 375
Likes (Given): 467
Likes (Received): 479
They have a throttle control lever for that purpose. If you have a 'remote' throttle control cable, there are provisions on the throttle mechanism to install that set up as well.
post #6 of 9 Old 01-25-2018, 08:50 PM
Thanks (Given): 10
Did it on my sonís go kart a couple years ago. Ironically it was the same engine I used on my old ariens for a couple years. The go kart had an 11hp Tecumseh snowblower engine on it, so I swapped them!
There are some videos on YouTube that I referenced. There are probably even more now. If I recall correctly, there are multiple options for how to rig up the cable.
Saewoody is offline
post #7 of 9 Old 01-25-2018, 08:57 PM
its right under the air filter. you normally have to cut off the z bend on the throttle cable to make it work
arienskid is offline
post #8 of 9 Old 01-25-2018, 11:29 PM
GustoGuy's Avatar
Thanks (Given): 47
Thanks (Received): 74
Likes (Given): 65
Likes (Received): 127
Extremely easy. I own 3 Predator 212cc's. I only have a cable throttle on my mini bike but the engine is made to set up a throttle on and has all the parts you need to do so. I don't bother on the snowblowers since they are almost always run at full throttle. The mini bike however is were the throttle works well.
GustoGuy is offline
post #9 of 9 Old 01-26-2018, 12:06 PM Thread Starter
Thanks (Given): 92
Likes (Given): 70
Good, thanks for all the answers.
There are times I like to idle my snowblower, talking to neighbors, refilling gas, using the shovel, changing gloves.
