Carb leak on Tecumseh HSSK50 - Snowblower Forum : Snow Blower Forums
Old 01-25-2018, 06:07 PM Thread Starter
Dave9354's Avatar
Likes (Received): 14
I have a small drip that looks like it is coming from the fuel inlet fitting on the carb. Does anyone know how to remove this fitting from the carb body? Never took one out. What keeps it from leaking? Carb # Tec-640084. Engine # hssk50-67364S.
Dave9354 is offline
Old 01-25-2018, 06:27 PM
Jackmels's Avatar
Thanks (Given): 111
Thanks (Received): 168
Likes (Given): 379
Likes (Received): 710
Replace the Gas Line First.
Jackmels is online now
Old 01-26-2018, 09:32 AM
Hi Dave9354
If it is a plastic fuel inlet fitting, just remove it with pliers and when you are putting it back in, use red locktite on the knurled parts of the fitting. That's what I always do and have never had one leak. If it is metal then I'm not sure what you can do.
Regards
Snoman110
snoman110 is offline
Old 01-26-2018, 10:13 AM
deezlfan's Avatar
Likes (Received): 30
If it's the plastic fitting don't twist it to remove it. That will split the plastic and you will need to replace it. Pull straight away from the carb body if you are going to remove it at all.
There's just one thing I'll guarantee , the best things in life, they sure AIN'T FREE !!
88 Craftsman II Trac-Plus 10/32 [wheeled conversion]
71 Ariens SnoThro 6/24 [Predator 6.5 repower]
72 Ariens SnoThro 6/24 with original Tecumseh H60
7? Ariens Tractor with rotary mower attachment [Tecumseh HSK100 repower]
deezlfan is offline
Old 01-26-2018, 11:05 AM
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3912
Likes (Received): 1505
I think this is the carb you're talking about. As mentioned above I'd make sure it's not the fuel line or clamp causing the problem before you try to pull that fitting out of the carb.
Old 01-26-2018, 06:08 PM Thread Starter
Dave9354's Avatar
Thanks guys! I will try the lo title.
Dave9354 is offline
Old 01-26-2018, 06:27 PM
Thanks (Given): 58
Thanks (Received): 66
Likes (Given): 54
Likes (Received): 163
if plastic inlet is cracked u can replace it or just buy a china clone complete carb from ebay or amazon, getting it will take time though. hopefully its just the fuel line thats cracked.
search utube for "fixing the plastic fuel inlet Carburetor tecumseh"
or use "Carburetor 640084" for ebay/amazon"
MY VIDS ON FIXIN HER UP
vinnycom is online now
Old 01-30-2018, 02:16 PM Thread Starter
Dave9354's Avatar
It ended up being a leaking fuel inlet. Put silicone around the valve and it has stopped leaking. Quick fix. New carb is only 9.00. Should be here Friday. problem solved!
Dave9354 is offline
