Reminder to check your oil - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-04-2018, 03:25 PM Thread Starter
Ian Ariens 924's Avatar
Thanks (Given): 20
Likes (Given): 40
Likes (Received): 21
My neighbour looked sad this morning after 5” of fresh wet snow fell last night and his snowblower won’t start.
He was shovelling instead of walking behind his trusty Toro 5hp
Its a 7 hp, 24 inch from late 70’s
Sure enough has gas in tank, oil is low.”But I just added 1 cup”
Anyway, rope start won’t move,so I removed the belt cover, tried to turn pulley, it’s stuck.
So, owner had just added a cup of oil, I filled it to the full line another 1 1/2 cups at least and put a pipe wrench on the pulleys ,and the engine turns.
Gave a few turns ,it loosened up nicely.
Buttoned it back up,hit the electric start and off it goes.
Fixed till he runs it low on oil again.
Btw, replaced this engine 2 years ago for a broken connecting rod.
Moral is check your oil every time you use it, keep it full.
Ariens 924334 11 hp 28
Ariens 924024 8 hp 32 now a 10 hp
Ariens 910008 7 hp 24
Ian Ariens 924 is online now
post #2 of 9 Old 02-04-2018, 04:06 PM
Thanks (Given): 21
Thanks (Received): 63
Likes (Given): 254
Likes (Received): 239
I thought most newer engines had low oil shutoff....Guess I was wrong.
jsup is offline
post #3 of 9 Old 02-04-2018, 04:20 PM
guilateen02's Avatar
Thanks (Received): 30
Likes (Received): 109
It's just a habit for me. Check fuel and oil every time on start up. It's part of the starting procedure. I even showed my oldest. Gave him a test one day on the generator one day and he passed. He has to know how to start that thing up if I'm not home cause my wife can't pull start anything in the garage.
74 Ariens 832
8? FMC Bolens 824
02 White 4x4 Snow Boss
90 Lawn Boy ST320
88 Honda 300FW w/plow
guilateen02 is offline
post #4 of 9 Old 02-04-2018, 05:52 PM
Thanks (Given): 118
Thanks (Received): 278
Likes (Given): 358
Likes (Received): 638
I'm not aware of blowers with low oil shutoffs (that doesn't mean they don't exist, obviously). The only engines I have with low-oil shutoffs are generators. One has an oil filter and pressurized lubrication, and senses low oil pressure. The other uses splash lubrication, so it must be more of a level sensor.
My assumption is that, at least in part, it's tougher to add a low-oil shutoff to splash-lubricated machines that will get tilted a lot during use, like blowers. If it basically used a float for a level sensor, you might have engines shutting down while driving a blower up into a snowbank, or running your tractor across a hill, etc.
Ian Ariens 924, I'm glad you were able to help get your neighbor's machine running again, that's awesome. Nice work. I'll confess I don't check mine as often as I should. Hopefully at least if it was something drastic, the puddle on the floor would alert me, or smoky exhaust. But I should check more often, thanks for the reminder.
post #5 of 9 Old 02-04-2018, 06:12 PM
Likes (Given): 382
dont most of the chondas have low oil shutdown ? my 208cc powerfist has it.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #6 of 9 Old 02-04-2018, 06:32 PM
Thanks (Given): 118
Likes (Given): 358
Nice, that's a great protection feature!
I guess I need more exposure to the newer engines My youngest big engine (generator/tractor/blower) is 18 years old.
post #7 of 9 Old 02-04-2018, 07:00 PM
Likes (Given): 382
definitely a good feature......but it shouldnt be thought of as a reason not to check the oil before each use.
28 " Ariens Sno Tek
Toro CCR ss
post #8 of 9 Old 02-04-2018, 07:55 PM
Thanks (Given): 21
Likes (Given): 254
Yes, all the Predators do as far as I know. It's referred to as the "yellow wire".
I just thought it was a standard feature. It's a cheap thing to add, about $10 retail for the part, so must cost about $3 or less at the factory wire. I'd pay $10 more for an engine with one.
jsup is offline
post #9 of 9 Old 02-04-2018, 07:57 PM
Thanks (Given): 21
Likes (Given): 254
Chevy has been putting it in cars for years. There's an oil pressure switch that will kill spark if the pressure drops off below 3PSI I think it is. I forget.
jsup is offline
