5 hp Tecumseh dry plug, primer seems to work, runs fine once started - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 02-20-2018, 03:15 PM Thread Starter
I just came into a 5 hp Tecumseh blower. I went through the carbs and did some general maintenance and got her started up. When I went to start it up this morning I couldn't get it to fire up. Pulled the plug and it was dry. After priming, pulling, priming, pulling, etc the carb was overflowing with gas, but still a dry plug. I ended up pulling the plug and throwing some gas directly into the cylinder and it fired right up and ran like a top. I turned it off and tried pull starting it and it fired right up.
Any ideas? Seems strange to me.
Thanks in advance!
kippstakes is offline
post #2 of 19 Old 02-20-2018, 06:21 PM
Likes (Received): 20
Unit is tilted so gas in carb can't run into the combustion chamber? Does one wheel have less air than the other? A spider built a cocoon at the bottom of the carb, essentially making a dam that the fuel can't flow over? Dunno. Just swingin' wild here. LOL
jrcjr is offline
post #3 of 19 Old 02-20-2018, 06:27 PM
Likes (Given): 353
Likes (Received): 586
is the bowl gasket in good shape ?
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 19 Old 02-20-2018, 06:58 PM
tdipaul's Avatar
Thanks (Received): 70
Likes (Given): 243
Likes (Received): 285
I had an old 440 jet ski that acted like this.
The carbs were fine
It had low compression due to stuck rings.
Low compression also results in low suction (to pull in fuel)
Check compression
And also for air leaks in between carb and cylnder head
1989 John Deere 1032
1979 Toro 5/24 38040 (now a 6.5/24)
2015 Snapper Pro SW30 52" Mower
tdipaul is online now
Likes jtclays liked this post
post #5 of 19 Old 02-20-2018, 06:59 PM
AL-
AL-'s Avatar
Thanks (Given): 7
Likes (Received): 29
Thanks in advance!
How did the choke work ... you only mentioned priming.
AL- is offline
post #6 of 19 Old 02-20-2018, 07:20 PM
Likes (Received): 302
5641456 work.
post #7 of 19 Old 02-20-2018, 07:42 PM
scrappy's Avatar
Thanks (Received): 39
Likes (Given): 36
Likes (Received): 91
A spray can of starting fluid is a handy thing to have around.....
scrappy is offline
post #8 of 19 Old 02-20-2018, 09:04 PM
Thanks (Given): 509
Thanks (Received): 679
Likes (Given): 3831
Likes (Received): 1472
I'm thinking air leak too. Carb to intake elbow or elbow to block. Had the same problem with a 10hp snapper. Found it was just loose bolts keeping it from starting.
post #9 of 19 Old 02-22-2018, 12:40 AM Thread Starter
Copression feels solid, it's not boggy when pulled and has good resistance. There doesn't appear to be any blow-by around the head gasket either. Also when it runs it runs strong and has no trouble tackling heavy snow/loads. It's at my gf's place, who I fixed it for (so I would have to shovel her nightmare driveway anymore), so I can't do a compression check at the moment. Next time I go over. It's not an old blower, from what she said the thing probably has under 25 hours on it. I will also check the elbow to block bolts when I get a chance.
The choke is functional but seems to have no effect on delivering fuel to the cylinder.
The carb and intake were clean when removed, so I doubt it's an obstruction. Considering that it runs well and restarts once ran I would rule that out.
Maybe it was just a fluke and it will start right up next time, we'll see next snow storm.
Thanks, guys.
post #10 of 19 Old 02-22-2018, 01:45 AM
Thanks (Given): 54
Thanks (Received): 62
Likes (Given): 50
what do u mean. if moving the choke from on to off and vice a versa does not change engine sound or rpms then thats wrong.
choke only controls the amount of air entering carb. on means less air(air is choked=less), off means more air for normal operating condition when warmed up from a cold start.
MY VIDS ON FIXIN HER UP
vinnycom is offline
