'06 Ariens 724 w/ OHV 7hp Tecumseh, air cleaner ??? - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-08-2018, 06:27 PM Thread Starter
Hello All !
Just picked up a '06 Ariens ST724E (932046) w/ OHV 7hp Tecumseh, OH195SA spec# 72560g.
First time on here and really, really dumb question but where is the air cleaner, / filter?
I am going thru it and just wanted to see air cleaner and determine if OK or needs service.
I see the carb and did'nt want to take all that apart if its not under there, but it would almost
have to be? right ? I have poured thru manuals and online parts catalogs and air cleaners are
never mentioned, not even on Ariens Model specific owner/operator manual I found online.
all help is appreciated, I did look at stickys and no OHV tecumseh sticky was there.
z27ls3 is offline
post #2 of 5 Old 11-08-2018, 06:37 PM
Dave9354's Avatar
Likes (Received): 14
Snowblowers do not have air cleaners. Lawnmowers do because of the dust.
Dave9354 is offline
post #3 of 5 Old 11-08-2018, 06:41 PM
aveteam's Avatar
Thanks (Given): 11
Likes (Given): 17
Likes (Received): 8
Just chiming in really quick. I have the same exact model and it does not have an air cleaner. Snow isn't much of a wear threat to an engine
Hopefully you find yours in great shape!
Sent from my LG-M322 using Tapatalk
"Where's that confounded bridge"? - Robert Plant, "The Crunge"
aveteam is offline
post #4 of 5 Old 11-08-2018, 07:07 PM Thread Starter
OK and wow, never would have guessed that...............
z27ls3 is offline
post #5 of 5 Old 11-08-2018, 07:43 PM
Thanks (Given): 88
Thanks (Received): 174
Likes (Given): 68
Likes (Received): 406
Plus an air filter may get wet and freeze starving the engine.
JLawrence08648 is offline
