Handle warmers dim the headlight - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-18-2018, 07:59 PM Thread Starter
Hi I added a set of universal handle warmers to my old faithful Ariens ST1236 this morning. When I started it up the light went dim when I turned the switch on the handle warmers. I spliced the feeder for the handle warmers into the power coming off the electric starter that goes to headlight. Any idea why the warmers are drawing from the light?
Jmannarino is offline
post #2 of 5 Old 11-18-2018, 09:16 PM
GeekOnTheHill's Avatar
Thanks (Given): 11
Likes (Given): 53
Likes (Received): 32
I'm not familiar with the machine, but I assume everything is powered by the battery, which has a limited current capacity. Apparently you're exceeding it.
Voltage is constant in a parallel circuit, amperage at each load is determined by the resistance of the load, and wattage is the product of voltage x amperage. But batteries have a maximum wattage capacity that is the voltage multiplied by the amperage capacity. Whatever wattage is consumed by the hand warmers is no longer available to the lights.
Richard
GeekOnTheHill is offline
post #3 of 5 Old 11-18-2018, 09:48 PM
Thanks (Received): 90
Likes (Given): 24
Likes (Received): 223
Your generator is not putting out enough power to run both the light and the warmers. Mine did the same when I added universal warmers, so I put switches for the light and the warmers, so I can have full heat during the day with no light, or full light at night with no heat for warm nights, or 1/2 heat and 1/2 light for warm moon-lit nights ! It is a compromise, but it works for me.
RIT333 is online now
post #4 of 5 Old 11-19-2018, 08:20 AM
Consider swapping out the bulb in the headlight for LED? It will pull fewer amps and tax the system less?
J-Roc is offline
post #5 of 5 Old 11-19-2018, 07:43 PM Thread Starter
First let me say what a great forum! Thanks for the quick responses. I really appreciate it. I will put the light on a separate switch.
