Ariens 28 deluxe fuel shut off dial broke off - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 11-22-2018, 03:01 PM Thread Starter
I have the above snowblower puchased in 2014. Works great, trouble free. Today, while blowing snow, the fuel shut off valve broke off spilling gas everywhere. Very strange. Is this common? Is it an easier repair?
Gschimma is offline
post #2 of 8 Old 11-22-2018, 04:17 PM
Thanks (Given): 509
Thanks (Received): 680
Likes (Given): 3834
Likes (Received): 1474
to SBF Gschimma
I wouldn't say it's common but it's cheap plastic so .... it happens.
Most just slip into the fuel line and have a compression clamp at each end. The valves can be had at a hardware or big box store usually.
Does this look like yours ?? This one is straight in line, some are 90 dregree.
https://www.homedepot.com/p/Briggs-S...B&gclsrc=aw.ds
post #3 of 8 Old 11-22-2018, 04:46 PM Thread Starter
Thanks for your repky. The knob is plastic but the rest is metal. https://az417944.vo.msecnd.net/graphics/e-pics/ariens/large/20001436.jpg
Gschimma is offline
post #4 of 8 Old 11-22-2018, 05:19 PM
Thanks (Received): 101
Likes (Given): 102
Likes (Received): 243
2014 should be a LCT made engine, pics of it would confirm but if it is the LCT this is the one you need, Had a bad one on a used blower I purchased to resell and then I broke one over tightening it into the tank so just snug will do but this is the shutoff that screws into the tank.
https://www.ebay.com/itm/OEM-Lauson-...JsrV:rk:2:pf:0
OK just seen your link, YUP thats a LCT.
Dauntae is online now
post #5 of 8 Old 11-23-2018, 10:01 AM
Thanks (Given): 509
Likes (Given): 3834
It should just be a matter of unscrewing the remaining part from the tank and screwing the new one in, slipping the line on and you're back in business.
post #6 of 8 Old 11-23-2018, 10:43 AM
Thanks (Given): 21
Thanks (Received): 63
Likes (Given): 254
Likes (Received): 239
An OEM honda shutoff valve has a provision, bracket, that you can put under a screw. If you have the ability to do that, and the original isn't held tight anywhere this may be a good replacement. These can be hard to turn if they aren't held in place.
These are just the first to links I found. I'm sure you can get them anywhere. I just wanted to give you an idea.
Here's an example:
https://www.ebay.com/itm/262159626352
Here's a generic example:
https://www.ebay.com/itm/Inline-Fuel...-/271826198319
jsup is offline
post #7 of 8 Old 11-23-2018, 04:22 PM
1132le's Avatar
Thanks (Given): 26
Thanks (Received): 81
Likes (Given): 59
Likes (Received): 178
[QUOTE=jsup;1614151]An OEM honda shutoff valve has a provision, bracket, that you can put under a screw. If you have the ability to do that, and the original isn't held tight anywhere this may be a good replacement. These can be hard to turn if they aren't held in place.
Here's an example:
https://www.ebay.com/itm/Inline-Fuel...-/271826198319[/QUOTE
Those will not work for him
1132le is online now
post #8 of 8 Old 11-23-2018, 04:43 PM
GeekOnTheHill's Avatar
Thanks (Given): 11
Likes (Given): 53
Likes (Received): 32
That's strange. What would cause something like that to happen, especially while the machine is in operation? There's no stress on it that I can tell.
Richard
GeekOnTheHill is offline
