Head Gasket - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 11-28-2018, 05:28 AM Thread Starter
Likes (Received): 6
Head Gasket
I've gone to the dealer twice so far for a head gasket for my Ariens 924116 ST 1028 HMSK 100. He says he can't find it because there are three different types and need the exact model number. I wrote down every number on this machine including frame and shroud. I'm I missing some place I should check?
snowman123 is offline
post #2 of 16 Old 11-28-2018, 06:32 AM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 632
How much engine info did you get? For instance, my Tecumseh OHV is an OHSK100 221608B. Just calling it an OHSK100 (the OHV version of your L-head HMSK100) wouldn't fully describe it. My engine info is on the sheetmetal shrouds on the engine.
post #3 of 16 Old 11-28-2018, 08:19 AM Thread Starter
Likes (Received): 6
All of that, every number I could find and being heavy equipment mechanic waste water plant I'm pretty good at it.
post #4 of 16 Old 11-28-2018, 08:31 AM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
jacks small engine has the breakdown of each motor, yet hmsk = h=horizontal, m=medium frame, sk=snowking , without a oh which means it's a overhead valve you should have a flathead snowking which uses a 36451 gasket part number on all 3 listed models using jacks part search
132619 is offline
post #5 of 16 Old 11-28-2018, 08:51 AM Thread Starter
Likes (Received): 6
Thanks but it doesn't look like that number lines up I'm assuming the hm listed is suppose to be hmsk I don't know. I punched in 924116 018396 and didn't see anything.
post #6 of 16 Old 11-28-2018, 09:00 AM
Thanks (Given): 118
Likes (Given): 358
I'm pretty sure I got a parts list & diagram for my engine somewhere (not at home, so I can't check). If you can find that for your engine, you should be able to confirm the head gasket number, even if the dealer is unsure.
post #7 of 16 Old 11-28-2018, 09:07 AM
Thanks (Received): 28
Likes (Received): 41
You just need the model and spec # from tecumseh engine. If its a Hmsk100 i see 2 different head gaskets listed 34923a or 36451. But with out the spec # its a guess. Always look engine parts up by the engine # the lookup from the snowblower makers can be wrong.
351beno is offline
post #8 of 16 Old 11-28-2018, 09:08 AM
Thanks (Given): 7
Likes (Given): 411
i looked using the engine hmsk 100 it came up showing only the one part number for a flathead
https://www.jackssmallengines.com/ja...ontal/hmsk-100
132619 is offline
post #9 of 16 Old 11-28-2018, 09:13 AM
Thanks (Given): 7
Likes (Given): 411
the link i posted above if the op adds the spec number he should be ok. as we know it's not rocket science to find a part number,, op remove the starter button and get the rest of the spec off the engine cover click on the correct one in the link
132619 is offline
post #10 of 16 Old 11-28-2018, 09:25 AM
hmsk100-159065s head gasket # 34923a
hmsk100-159311v head gasket # 36451
351beno is offline
Likes 132619 liked this post
