Tecumseh 5hp fuel pouring from the carb - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 11-28-2018, 03:23 PM Thread Starter
Gta_g20's Avatar
Noticed fuel pouring from the carb when I primed it this season. Didn’t inspect and saw fuel dripping from the bowl. Pulled the carb and noticed the bowl gasket was warped. Bought and installed new bowl and gasket. Started he blower back up and then shut it off went to restart and same thing again
Ariens 724E
Gta_g20 is offline
post #2 of 22 Old 11-28-2018, 03:24 PM Thread Starter
Gta_g20's Avatar
Any help is appreciated
Ariens 724E
Gta_g20 is offline
post #3 of 22 Old 11-28-2018, 03:31 PM
db130's Avatar
Thanks (Given): 15
Thanks (Received): 64
Likes (Given): 204
Likes (Received): 139
Either the float is damaged or the float needle is not closing the flow of fuel even when the float is level (it may be that there isn't a good seal between the float needle and the float needle seal).
db130 is offline
post #4 of 22 Old 11-28-2018, 03:52 PM
Thanks (Given): 135
Thanks (Received): 266
Likes (Given): 358
Likes (Received): 900
Here ya go.
https://www.ebay.com/itm/CARBURETOR-...edirect=mobile
post #5 of 22 Old 11-28-2018, 04:01 PM
As DB130 said, check to see if the float is damaged or sticking. Once the float is removed,shake it to see if you hear liquid inside it, if so replace the float. Since you will have it apart to check, put a needle and seat kit in.
snoman110
snoman110 is offline
post #6 of 22 Old 11-28-2018, 05:03 PM
Thanks (Given): 15
Thanks (Received): 62
Likes (Given): 54
Likes (Received): 170
Does it do that if you don't prime it? The primer simply pushes fuel into the carburetor throat, which, based on your photos, looks like where the fuel is coming from. You may simply be overpriming . . . If it does this *without* priming, it likely is the float.
tadawson is online now
post #7 of 22 Old 11-28-2018, 08:47 PM Thread Starter
Gta_g20's Avatar
Thanks guys. I’ll pull the bowl in the morning and check to see if it’s still happening without priming. And if so I’ll look into the needle seal and the bowl
Ariens 724E
Gta_g20 is offline
post #8 of 22 Old 11-28-2018, 08:55 PM
evh
evh's Avatar
Likes (Given): 41
My bet is the needle is not sealing correctly and likely a new one is needed. I just had that happen on a Toro. You could look in the intake and see it full of gas. A new needle solved it.
One thing I have learned is that living richly is less about the net worth on your bank statement and more about the value of the lessons you offer those who want to learn from you.
evh is offline
Likes Toro-8-2-4 liked this post
post #9 of 22 Old 11-28-2018, 10:16 PM
Thanks (Received): 112
Likes (Received): 292
While your checking things, check your oil to see if all the gas that has leaked through the carb ended up in the crank case with the oil. You may find the level WAY high on the dipstick or filler port. Also see if it smells like gas.
After an event like you have, I would change the oil as a matter of routine.
Work fascinates me.
skutflut is offline
Likes Grunt liked this post
post #10 of 22 Old 11-28-2018, 11:13 PM
Tecumseh Carb Leaking:
Originally Posted by Gta_g20 View Post
Thanks guys. Iíll pull the bowl in the morning and check to see if itís still happening without priming. And if so Iíll look into the needle seal and the bowl
Check condition of the main fuel pipe. Place fingers around hose, if they are black, hose may be rotten. Also check condition of the small primer hose going into carb.
I also had Chinese Carb leak. It was the tang on the float lever was bent to wrong way holding the float at bottom of the bowel. Straighten tang, check float is level, or use 5/32 drill bit to check float height.
AdrianZ is offline
