Left wheel not turning under small load - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 11-29-2018, 10:00 PM Thread Starter
Thanks (Received): 7
Likes (Received): 10
Greetings. I have a old craftsman 8/24 with a tecumseh engine. It starts well with 1 or two primes and runs ok but once it hits a patch of snow the left wheel will stop turning and I'm sure I can see the shaft and pin turning in the middle. Any ideas? I'm ready to order a new wheel or have it serviced since I got it for free and it starts great. I did notice that the bucket tends to lift on a small mound of snow but that's another issue.
Xilbus is online now
post #2 of 14 Old 11-29-2018, 10:10 PM
Thanks (Given): 91
Thanks (Received): 183
Likes (Given): 70
Likes (Received): 420
Pin broken? It can't be turning, it can't, unless you are nuts, seeing things, eyesight bad, or the pin is broken, or axle broken somewhere? 2 of these make sense, the other 3 are just for fun. Interesting post, get back to us.
post #3 of 14 Old 11-29-2018, 11:03 PM
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3912
Likes (Received): 1505
What is the model number of the machine from the ID tag ??
With the machine not running and the left wheel off the ground some and tipped onto the right wheel can you manually turn the left wheel. Does it seem to be pinned to the shaft or does it rotate on the shaft ??
post #4 of 14 Old 11-30-2018, 12:31 AM Thread Starter
Thanks for the replys guys. It's a bit frustrating because the snow is melting so I have to wait in order to reproduce the problem lol. I'll check tomorrow to see if the left wheel spins freely. And I'll take some close up pics of each wheel.
post #5 of 14 Old 11-30-2018, 08:24 AM
Thanks (Given): 91
Likes (Given): 70
As Kiss4aFrog stated, put the snowblower standing upright on the auger housing face then you can turn the wheels independently, pull the pin, undo the bolt, usually the left side is one hole with a bolt, the right side is a lynch pin and you have a choice of two holes, one the pin goes through both the axle and the wheel, the other you don't move the wheel and put the pin through the hole in the axle only not going through the wheel.
Your Craftsman was either built by MTD or Murray. If it has a rectangular impeller outlet it is a Murray. Both machines are very very similar and work the same way. 8hp with only a 24" width is a powerful combination. This machine will last you a long time and is completely fixable for many years forward.
post #6 of 14 Old 11-30-2018, 09:24 AM Thread Starter
Kiss. I lifted the side a bit and my left wheel turns freely up and down. I did the same for the right wheel and I can feel all the gears working and the left wheel wants to turn a bit when turning the right wheel. Picture with pull pin is left wheel and picture with straight pin is right wheel
ID:	149387   Click image for larger version
post #7 of 14 Old 11-30-2018, 09:28 AM Thread Starter
Model numbers
post #8 of 14 Old 11-30-2018, 09:57 AM
Thanks (Given): 161
Thanks (Received): 297
Likes (Given): 390
Likes (Received): 974
Pull that pin out of your left axle. Line up the holes in the wheel with the inner set of holes on the axle shaft and reinstall your pin so that it is going into the wheel and through the axle. Done.
Make the pin on the left side go through the wheel, like it is going through your right wheel.
Likes Town, Grunt liked this post
post #9 of 14 Old 11-30-2018, 10:53 AM
Thanks (Given): 62
Thanks (Received): 117
Likes (Given): 94
Likes (Received): 134
At the moment you have only the right wheel driving the machine. This is good for turning, but not so good for traction. If you do as @micah68kj says then you will have two wheel traction but your turning will be more difficult. So you have a compromise. When I had machines like that I set them up as @micah68kj suggests. Traction is more important for me.
Town is online now
Likes Grunt liked this post
post #10 of 14 Old 11-30-2018, 11:26 AM
Grunt's Avatar
Thanks (Given): 250
Thanks (Received): 298
Likes (Given): 2991
Likes (Received): 552
I agree with Joe and Town. Your photo shows what appears to be a lock washer on the axle between the pin and wheel, not sure why. You will/might have to remove it in order to remove the wheel. I would remove the washer and wire brush the axle and then apply some grease to make future removal easier.
Thanks micah68kj thanked for this post
