Ariens ST824 924050 auger belt jumps off - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 12-03-2018, 01:47 PM Thread Starter
Thanks (Given): 8
Likes (Received): 10
Hey guys , i need some help to figure out this problem.
Made a quick video ... easier for me to show you that way
Any tips?
octane is offline
post #2 of 15 Old 12-03-2018, 02:13 PM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 32
Likes (Given): 43
Likes (Received): 216
The length looks to be nearly correct - 1/10" long, but I wonder if the width of the belt is correct.
The part numbers appear to be 72066 for the tractor belt (34" x 3/8"), and 72086 for the attachment belt (39.4" x 1/2"). I'm no expert but 1/10" extra length I would suspect wouldn't be the outright cause.
That belt seems to be riding kinda high to me though. Is the belt an actual Ariens/Gravely 72086 or 07208600? Or simply a belt that measured the (near) length correct?
1974 Ariens 922008/922003 "Frankenstein", my dad's 1st new snowblower
1971 Ariens 922002/922003 "The Badger", recent addition, ready for snow
1971 Ariens 922002/922003 "Juneau", finally ready for snow
1971 Ariens 910962/910995 "Bill", SOLD 3/7/2019
tlshawks is offline
post #3 of 15 Old 12-03-2018, 02:28 PM Thread Starter
Thanks (Given): 8
Im not sure if its an original belt, I just went to a local shop who sells and service Ariens blowers.
Its 39.5" in lenght and 0.5" wide. From my research thats correct.
octane is offline
post #4 of 15 Old 12-03-2018, 02:53 PM
tlshawks's Avatar
Thanks (Given): 24
Likes (Given): 43
Hmmm. One thing I just noticed from when you first started until you engaged the idler.
From the owner's manual, page 8, "Replacement of Blower Housing"...
5. The idler on the attachment belt is adjustable. If the belt slips, adjust the idler in the slot in the idler arm to apply more tension to the belt. Belt should declutch when attachment clutch is disengaged.
When you first started the blower up, the belt was declutched...it was not spinning - and the two idlers were in alignment together. Then you engaged the clutch and disengaged the clutch several times. But when you disengaged the clutch, the belt kept spinning but with a lot less tension on it.
To me...why does that occur?
Edited to add...on second look and studying pictures in the manual...my hunch would be that maybe the adjustment on the attachment idler, that bolt that holds it in place to the idler arm appears to be fully to the right. Maybe try loosening that bolt and moving the idler left a bit to take some tension off the idler arm when engaged would give it enough to fully disengage the belt...and therefore not slip off.
tlshawks is offline
post #5 of 15 Old 12-03-2018, 02:58 PM
db130's Avatar
Thanks (Given): 15
Thanks (Received): 64
Likes (Given): 204
Likes (Received): 139
I could think of two things, but am not 100% certain.
1) From the video, it looks like the tensioner is set at the maximum travel to allow the most tension. With tensioner engaged, how much belt deflection do you have? The general rule of thumb is 1/2"
https://allthumbsdiy.com/outdoor-pow...se-snow-blower
2) how's the auger bearing?
db130 is online now
post #6 of 15 Old 12-03-2018, 03:45 PM Thread Starter
Thanks (Given): 8
The reason why its still spinning, i believe is because the auger break (https://www.jackssmallengines.com/ja...riens/52404800) is worn out.
It will stop spinning after 5-10 more seconds.
You are right about the idler wheel , it is adjusted for maximum tension (all the way to the right), i did this just to try take of some slack in the belt.
octane is offline
post #7 of 15 Old 12-03-2018, 03:51 PM Thread Starter
Thanks (Given): 8
I will check the deflection tomorrow, but its pretty tight ... .5" sounds about right.. yupp the idler wheel is adjusted to maximun tension , all the way to the right.
Hmm how do I check the auger bearing?
octane is offline
post #8 of 15 Old 12-03-2018, 03:57 PM Thread Starter
Thanks (Given): 8
Could the belt be jumping of because the auger break is worn out??
I mean , if the break would engage , it would apply drag on the belt, at the moment I release the handle.... wouldn't it?
octane is offline
post #9 of 15 Old 12-03-2018, 04:50 PM
Thanks (Received): 155
Likes (Given): 52
Likes (Received): 544
I'd put a couple of washers under the little bar that is supposed to keep the belt on the pulley and get it closer to the center of the pulley....if in the right position, the belt can't jump off...
cranman is online now
post #10 of 15 Old 12-03-2018, 05:01 PM Thread Starter
Thanks (Given): 8
Do you mean the U bar?
octane is offline
