Magnetron upgrade - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-05-2018, 02:43 PM Thread Starter
Magnetron upgrade
I have a 1978 Toro 8/26 two stage snowblower. It has a briggs and Stratton engine. The magneto ignition is gone and it needs to be replaced. I was pondering the idea of upgrading to a magnetron. Has anyone does this with success or/and know where I can get the correct part online?
bandito is offline
post #2 of 9 Old 12-05-2018, 03:47 PM
Thanks (Given): 16
Thanks (Received): 62
Likes (Given): 55
Likes (Received): 172
A magnetron is the power tube in microwave ovens and microwave radio transmitters . . . perhaps it goes by another term?
tadawson is online now
post #3 of 9 Old 12-05-2018, 03:55 PM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
don't hang me but i think the part was simply renamed,
132619 is offline
post #4 of 9 Old 12-05-2018, 04:05 PM
Jackmels's Avatar
Thanks (Given): 98
Thanks (Received): 152
Likes (Given): 295
Likes (Received): 606
I believe a Briggs lawn tractor Coil will work. Cranman posted doing this, Here's the Thread https://www.snowblowerforum.com/foru...ml#post1619577
Jackmels is online now
post #5 of 9 Old 12-05-2018, 04:56 PM
SayItAintSnow's Avatar
Thanks (Given): 20
Thanks (Received): 23
Likes (Given): 38
Likes (Received): 123
LOL.... No one's going to hang you here Woodie. These are all good people on this forum......
Briggs refers to their electronic ignition system that was developed sometime back in the 80's as the "Magnetron Electronic Ignition System". Kind of an odd name, because they have nothing to do with real magnetrons used in radar, microwave transmitters, or ovens....but some marketing "genius" probably dreamed the name up.....
Anyways, here's video that explains a typical installation, and a pdf on how to do this both for engines that originally had this system, and for those that didn't.
video:
pdf:
http://vanguardengines.myfaqcenter.c...A496A31A6.ashx
Hope this helps.
--- Clint Eastwood
SayItAintSnow is offline
post #6 of 9 Old 12-05-2018, 05:40 PM
Thanks (Received): 155
Likes (Given): 52
Likes (Received): 544
I have a large box of the Magnetron upgrades from Briggs....from the 80's......it was a great upgrade...but now I simply bolt on a modern single cyl coil from and Briggs.....easy peasy....works every time...never have to file points again. did three this week.
cranman is online now
post #7 of 9 Old 12-06-2018, 09:17 AM
Thanks (Given): 7
Likes (Given): 411
i did many myself cut the wire to the points add a plug bridge to work as a kill switch, super easy job. i just couldn't remember what briggs called them .to me a mag is a mag
132619 is offline
post #8 of 9 Old 12-06-2018, 09:55 AM Thread Starter
So any single cyl coil will work from briggs?
bandito is offline
post #9 of 9 Old 12-06-2018, 10:16 AM
Likes (Given): 52
I've done over 7,8,and 11 hp snowblower engines using 12 -20 hp vertical shaft mags....I've heard they are all interchangeable
