carb fuel leak Ariens 8526 - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-16-2018, 01:40 PM Thread Starter
Hi folks - Iím new to the forum. I have a continuous carb fuel leak from my Ariens 8526 when not primed, it leaks when the fuel line value is turned on. Itís a small steady stream coming from the same pinnhole as if it was over primed
I have a pic if I could figure out how to upload it here
sorry if this topic has been covered before, Iím trying to learn how to do the searches
Any help would be greatly appreciated
SWRufus is offline
post #2 of 5 Old 12-16-2018, 02:40 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 634
Hopefully you can post a pic. Worst-case, you could upload it to imgur.com, for instance, and post a link to that.
It sounds like it's overflowing the carb bowl. Perhaps the carburetor's needle valve, controlled by the float, may be leaking, and is not closing off the fuel flow. If that's the case, the rubber seat for the needle valve might need to be replaced. Or the needle may need to be cleaned, or perhaps the float has leaked, and allowed gas into it, which means the float sits too low, and does not close the needle valve properly.
Be careful of running the engine in this condition. Check your oil level. Make sure the oil doesn't smell like gas, and that the oil level hasn't risen. If the carb is overflowing, it can leak gas into the cylinder, which will get down into the crankcase. Oil with gas in it doesn't lubricate as well, and can cause engine damage. If the oil smells like gas, you can change it, and keep using the fuel shutoff. At the end of a run, you can close the fuel shutoff, and run the engine until it dies, so there is no fuel left in the carb.
post #3 of 5 Old 12-16-2018, 02:49 PM
Thanks (Given): 521
Thanks (Received): 687
Likes (Given): 3905
Likes (Received): 1498
. . . . to SBF SWRufus
If the picture is on your computer the easy way is right below the "Quick Reply" box. Hit the "Go Advanced" blue radio button and with the new screen scroll down and it will have a button on the left for "Attachements". Once you click on that it's just a matter of navigating to your C drive or whatever drive the photo is on and selecting the photo and then attaching it.
I don't know how to do it from a hosting site, sorry.
More info - - > https://www.snowblowerforum.com/foru...ures-host.html
post #4 of 5 Old 12-17-2018, 07:34 AM Thread Starter
Wow - thanks for the help & advice. Here is a pic.
I checked and the oil level has remained at the same level.
Thanks again - much appreciated!
SWRufus is offline
post #5 of 5 Old 12-17-2018, 09:39 AM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
being it's a old carb i would replace it, doing a fast search the number is likely Tecumseh 640349 or a Oregon 50659
if you give amazon a fast look over it maybe found for under 20 bucks.
given the age and how bad our gas is today, i would not think twice about a new carb simply for peace of mind
good luck with the project
132619 is offline
