new friction disk comes loose - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-16-2018, 04:43 PM Thread Starter
Question new friction disk comes loose
I have a Craftsman snowblower 1986 I replaced the bearings on the hex shaft also replace the friction disk. All back together and working however the friction disk keeps coming loose. Tightened is three times. Have washer lock washer and thread lock on shaft. Model is 536887220. Bewildered.
northwoodst is offline
post #2 of 12 Old 12-16-2018, 04:50 PM
Thanks (Given): 14
Thanks (Received): 8
Likes (Given): 49
Likes (Received): 46
I got so fed up with things loosening that I now have a $5 tube (Lowes) of blue loctite in my tool bag. This stuff works!!!!
foggysail is offline
post #3 of 12 Old 12-16-2018, 05:14 PM
Thanks (Received): 112
Likes (Received): 293
I am guessing here, but your friction disk rubber wheel is sandwiched between two metal plates, held together with 3 bolts and those are what is coming loose?
If so, buy three new bolts, long enough to accomodate Nylock nuts, and replace the current nuts and bolts with the nylocks, or try the Loctite method.
Work fascinates me.
skutflut is offline
post #4 of 12 Old 12-16-2018, 05:40 PM
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3908
Likes (Received): 1501
to SBF northwoodst
Friction discs do not take kindly to shifting while engaged and moving. Any chance you've been shifting it while it's still under power ??
Likes micah68kj liked this post
post #5 of 12 Old 12-16-2018, 06:08 PM
Thanks (Given): 522
Likes (Given): 3908
Looked up your machine and it isn't the sandwiched style where it's two plates squeezing on a rubber ring. You still don't want to shift on the fly but it sounds like something is damaged in there. Either the bolts or the holes. Maybe a little locktite is in order to hold it together.
You can get some Loctite at an auto parts store and they sell it in packets for a buck or buck fifty. More than enough for this application. You want to get 222 or 242. Just a low or medium strength.
Is this the disc for your blower ?
post #6 of 12 Old 12-16-2018, 06:13 PM Thread Starter
Thanks much, just rechecked the machine, there is supposed to be a 1/8" key, part 71203 that slides into the shaft and the friction wheel hub, apparently got ground up when the bearings on the hex shaft broke. Of course I cannot find the part.
post #7 of 12 Old 12-16-2018, 06:25 PM
Thanks (Given): 522
Likes (Given): 3908
Is it just a straight key or is it the half moon style ? Might try auto parts store, big box store or hardware store with pictures and measurements.
post #8 of 12 Old 12-16-2018, 08:35 PM
Thanks (Received): 90
Likes (Given): 24
Likes (Received): 225
I think you can find them at either Lowes or Home Depot.
RIT333 is online now
post #9 of 12 Old 12-16-2018, 11:48 PM
Likes (Given): 19
Likes (Received): 11
I've got the same machine and just changed the disc.. it's a square 1/8 inch key
Sent from my SM-G950W using Tapatalk
kenora is online now
Likes dbert liked this post
post #10 of 12 Old 12-17-2018, 01:44 PM Thread Starter
Thanks much I will check at an auto parts store.
