Friction wheel stuck and won’t shift - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-19-2018, 03:58 PM Thread Starter
Beginner here, I’m not exactly handy but have been able to keep my old JD TRS27 going. One issue it has is it won’t shift. I take off the bottom panel and the friction wheel is to the far right of the drive disk and I cannot get it to move on the shaft at all. I assume this should slide freely as I shift. Ideas on how to free this so I can clean and lube the shaft. Thanks
stewie is offline
post #2 of 9 Old 12-19-2018, 04:07 PM
Thanks (Given): 507
Thanks (Received): 355
Likes (Received): 1244
ALOHA From The Paradise City.
post #3 of 9 Old 12-19-2018, 04:16 PM
Thanks (Given): 91
Thanks (Received): 183
Likes (Given): 70
Likes (Received): 421
Something is bent or binding, mostly the latter. Clean the shaft with a solvent, spray a solvent under the friction disk, disconnect the shift linkage at the outside rear bottom, I believe it's a cable, try to move the friction disk. Make sure there is a space between the friction disk and the friction plate. The fiction disk moves sideways, the friction plate moves up and down. Up to meet the friction disk, down to disconnect creating a space thus the snowblower is not going to move. There has to be a space there. There are other reasons, check those first then repost.
post #4 of 9 Old 12-19-2018, 05:24 PM Thread Starter
Iíve sprayed and cleaned the shaft and it wonít slide at all. I do have space between the friction and drive discs. Here is a picture of how it sits.
Name:	TRS27 transmission friction wheel.jpg
stewie is offline
post #5 of 9 Old 12-19-2018, 05:35 PM
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3912
Likes (Received): 1505
What JLawrence suggested. Either the linkage is binding and that's really rare or it's the shaft the disc shifts back and forth on. Did you clean and lube the shaft in the back of the friction wheel or the one in the front of the picture ??
Sorry for messing with your post but I rotated the photo so it's right side up. I think it's easier to understand when it's orientated this way
Likes knu2xs liked this post
post #6 of 9 Old 12-19-2018, 05:47 PM Thread Starter
Thanks. Yes, the shaft in the back. The whole assembly from the friction wheel to the chain should slide on the shaft, correct?
stewie is offline
post #7 of 9 Old 12-19-2018, 06:28 PM
Thanks (Received): 11
Likes (Given): 43
Likes (Received): 24
Yes, it should all slide back and forth. Clean the hex shaft at the top and also the smooth round one on the bottom, use some brake cleaner or better still carb cleaner. Drain the gas and lay the blower on its side (look for where the engine pcv system is and have that at the top otherwise you'll get oil coming out) and spray whichever end is up and let it sit for a bit then tap on something sturdy with a rubber mallet to get it all moving, possibly tap a little one way and clean any schmutz off the shafts then tap the other way and clean the shafts again and repeat until it moves freely.
CRC Freeze off works pretty darn well and it smells better than PB Blaster so use that and spray all the shift linkages to make sure they all move freely.
Gear oil, aka 80w90 works good for chain lube so lube those up while you have it opened up.
notabiker is offline
post #8 of 9 Old 12-19-2018, 07:29 PM
Jackmels's Avatar
Thanks (Given): 112
Thanks (Received): 168
Likes (Given): 380
Likes (Received): 712
Need to use a Hammer. I position a Ball Joint Fork resting on the Friction wheel near the shaft, and Give it a Good Wack or 2. Once it Breaks Loose, You'll be fine.
Jackmels is online now
post #9 of 9 Old 12-19-2018, 07:33 PM
Thanks (Given): 91
Likes (Given): 70
After disconnecting the linkage, you may have to bang on it using a heavy hammer/hand "sledge" to get it to move sideways. Use something with a large surface area to spread out the force.
