LCT "SNOWKING" 291CC on a Husquvarna - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 12-28-2018, 04:19 PM Thread Starter
Thanks (Given): 21
Thanks (Received): 63
Likes (Given): 254
Likes (Received): 239
OK, HOW THE HECK DO YOU GET THE STARTER OFF THIS THING!?
I can't see any bolts holding this thing on? What keeps it in place? The starter is just spinning, usually, I can fix that, if I can get it off. I've fixed a number of starters, easy, if only I can get it off.
Any suggestions? Here's the engine model number: PW4HK19850781DEA0QTUVX5E1M
Thanks in advance.
jsup is offline
post #2 of 13 Old 12-28-2018, 04:28 PM
Thanks (Received): 157
Likes (Given): 353
Likes (Received): 588
Not sure if this helps. 208 cc lct
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 13 Old 12-28-2018, 04:34 PM Thread Starter
Thanks (Given): 21
Likes (Given): 254
Thanks, that's the correct starter. I just don't see what holds it in place. There doesn't seem to be a physical connection between the starter, part 10, and the bracket, part 33, or any other part. The breakdown doesn't even show bolts that go through it. It has to be simple, I'm just not seeing it.
jsup is offline
post #4 of 13 Old 12-28-2018, 04:40 PM
Likes (Received): 14
Just a hunch, is there an end plate that covers up the bendix? My bet is is you remove part 22, you will see the bolts coming in from the end of the starter.
bbwb is offline
post #5 of 13 Old 12-28-2018, 04:51 PM
SimplicitySolid22's Avatar
Thanks (Given): 51
Thanks (Received): 59
Likes (Given): 56
Likes (Received): 90
I believe the bolts are up by the neck of the starter where the Starter gear pops out in towards the engine side
SimplicitySolid22 is offline
post #6 of 13 Old 12-28-2018, 04:55 PM Thread Starter
Thanks (Given): 21
Likes (Given): 254
Upon closer inspection, and twisting my body like a circus contortionist, I can see screws that seem to come from the opposite side, meaning, It appears I have to take the whole thing front housing off, the housing that includes the recoil assembly, and the entire metal cover. Not the easiest way to get the starter out. I'll fool with it a bit tomorrow, but it looks like a lot has to come apart to do it. Layers, it's all about layers.
jsup is offline
post #7 of 13 Old 12-28-2018, 05:12 PM
Likes (Given): 52
Likes (Received): 547
That's why I like the old stuff.....
cranman is online now
Likes jsup liked this post
post #8 of 13 Old 12-28-2018, 05:14 PM
Thanks (Given): 33
Thanks (Received): 137
Likes (Given): 71
Likes (Received): 241
Yup, it's actually pretty easy... Just take off the recoil starter and then the Blower Housing (cover) and then you'll see the bolts around the bendix.
tabora is offline
post #9 of 13 Old 12-28-2018, 05:48 PM Thread Starter
Thanks (Given): 21
Likes (Given): 254
Thanks.
jsup is offline
post #10 of 13 Old 12-29-2018, 01:35 PM Thread Starter
Thanks (Given): 21
Likes (Given): 254
OK, got the starter out, and took it apart. It's a gear reduction starter. the smaller gear that runs off the motor, not the bendix side, is shattered. Is there any way to get this part so I don't have to bill this poor lady for a new starter. They aren't cheap, at Jacks they are $250. I've found them as low as $150 but that's STILL a lot of money.
Any suggestions? Anyone want/need pictures?
jsup is offline
