Clear Fuel Line - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-28-2018, 06:10 PM Thread Starter
Thanks (Given): 21
Thanks (Received): 63
Likes (Given): 254
Likes (Received): 239
Clear Fuel Line
Do you guys have a problem with clear fuel line? The stuff that comes in colors, Sterns is blue for example. I mentioned it to someone and they made a face, as if it were a crime against nature.
I've used it in numerous applications. Small outboards, snowblowers, power washers, never had a problem. Used it for years in one small engine, worked fine.
What do you think? Any reason NOT to use it?
jsup is offline
post #2 of 9 Old 12-28-2018, 06:33 PM
Thanks (Given): 88
Thanks (Received): 174
Likes (Given): 68
Likes (Received): 406
I used it when my local mower parts store was out of stock on the 1/4" rubber hose. It hardens after time, and if it comes in contact with the exhaust/muffler while it's disconnected, it instantly melts.
JLawrence08648 is offline
post #3 of 9 Old 12-28-2018, 07:13 PM Thread Starter
Thanks (Given): 21
Likes (Given): 254
It does melt. I did a 15HP Outboard with it about 10 years ago, still like new. If it hardens how long would it take to go bad? I don't care either way, hose is hose, just wonderin' what everyone thought.
jsup is offline
post #4 of 9 Old 12-28-2018, 07:52 PM
Thanks (Given): 88
Likes (Given): 68
The stuff I used harden in less than a year.
post #5 of 9 Old 12-28-2018, 08:10 PM
Yea it hardens, I picked up some yellow stuff from a store in North Pole. Used it on my dual sport for a decade and it's pretty stiff where gas touches it constantly, though where it fits over the petcock nipples (got two petcocks on one 5.9 gallon tank on my bike) it's still soft. I haven't noticed it being brittle but I haven't tried bending it into a U.
notabiker is offline
post #6 of 9 Old 12-28-2018, 10:12 PM Thread Starter
Thanks (Given): 21
Likes (Given): 254
Did it leak, crack?
jsup is offline
post #7 of 9 Old 12-29-2018, 08:33 AM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
they use the yellow on 2 stroke machines right from the factories so it can not be that bad .as to larger engines i prefer to stay with the double layer black fuel line ,just for safety.
132619 is offline
Likes jsup liked this post
post #8 of 9 Old 12-29-2018, 08:43 AM Thread Starter
Thanks (Given): 21
Likes (Given): 254
I get it. I've seen plenty of rubber go bad too, if you wait long enough. It gets spongey, some gets hard, depends on the composition I guess. Also, some braided line has cheap rubber where the gas seeps right through the rubber inside.
The only thing I like better about the clear stuff, is it's easier to work with when new. More flexible. Easier to route. Other than that, I don't see a huge difference.
jsup is offline
post #9 of 9 Old 12-29-2018, 08:49 AM
Thanks (Given): 7
Likes (Given): 411
fuel lines and ethanol . that's the issue , one i will never use is the clear one with the net in it
132619 is offline
