problem with shifter yoke - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-30-2018, 07:54 PM Thread Starter
Hi everyone,
My dad and I have the same snowblower. It's a Craftman 944.528394. Here's a link to the user's manual : https://drive.google.com/drive/folde...FBhQ3c4Y2VwZ1k
So this summer I changed both belts and the friction disk on mine. Everything went fine. Last weekend, I did the same on my dad's snowblower and I have a problem I need help with. The friction disk's nuts hit the shifter yoke when spinning. It only happens if the transmission is at the full reverse position or full forward. Here's a video :
https://photos.app.goo.gl/p2PUBgTjrnGZzRc87
Any idea how I can fix this ?
Thanks !
mroussel is offline
post #2 of 9 Old 12-30-2018, 08:17 PM
Thanks (Received): 157
Likes (Given): 377
Likes (Received): 603
duplicate post ? a bump may have been better
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 9 Old 12-30-2018, 10:01 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 634
Welcome to the forum!
Your manual link doesn't work, it seems to have been shortened (has a "..." in the middle of the link).
Is it possible that the bolts (and/or friction disk) were installed facing the wrong direction?
post #4 of 9 Old 12-30-2018, 10:36 PM Thread Starter
I fixed the link thanks for letting me know. No I made sure to reinstall them as they were. Even took picture just to be sure.
I tried to move or delete the other post in the Craftsman forum but couldn't find how.
mroussel is offline
post #5 of 9 Old 12-31-2018, 11:41 AM
Thanks (Given): 118
Likes (Given): 358
If it's assembled the same way, and the new parts match the old, then I'd wonder if something is causing more travel on the shift yoke than normal. During the swapover process, was something re-attached in a way that caused the shift lever to move the yoke further than it used to? Something mounted to a different pivot hole, etc.
post #6 of 9 Old 12-31-2018, 12:15 PM
SimplicitySolid22's Avatar
Thanks (Given): 56
Thanks (Received): 74
Likes (Received): 110
I believe yours is sibling to Husqvarna St227P.
Did you reinstall E-rings(C-Clips)(812000022 ) on either side of Jack shaft which I believe are your stops.
There should be one on each side.
SimplicitySolid22 is offline
post #7 of 9 Old 12-31-2018, 12:25 PM
Thanks (Given): 56
Do you have friction disc on in reverse????
post #8 of 9 Old 12-31-2018, 12:42 PM
Thanks (Given): 56
Whoop on yours you just have a retainer ring to Chain/gear side (12000012).
post #9 of 9 Old 01-05-2019, 02:10 PM Thread Starter
well there's a way to adjust the travel but at first I didn't touch it. I tried to play with it but it didn't change anything. The friction disk that was sent to me was defective so I will have to swap it next weekend. Maybe it will change something I don't know ...
mroussel is offline
