Starter for old John Deere 832 - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-01-2019, 11:34 AM Thread Starter
I bought a great old John Deere 832 this summer for my girlfriend. It runs great but she just can’t pull hard enough to get it started. I bought what I thought was the correct starter off eBay but it doesn’t extend the gear far enough to engage the ring gear on the flywheel. The starter is working properly and the gear is extending as far as it can. The eBay add said it would fit a 726 but I assumed it’d work. The snowblower was built in 1973 which was the first year for a 8hp Tecumseh on a John Deere snowblower. Does it take a different starter with a gear that extends a little further? If so, does someone have a part number for the starter I should be using?
The engine numbers are:
HM80
155013 (3 might be an 8)
Serial#2228D
Otterby is offline
post #2 of 11 Old 01-01-2019, 02:31 PM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
7hp is a small frame the 8hp is a medium frame ,as far as i can remember it uses a different starter
https://www.discountstarterandaltern...SABEgKv4fD_BwE
132619 is offline
Thanks Otterby thanked for this post
post #3 of 11 Old 01-01-2019, 07:04 PM
Ian Ariens 924's Avatar
Thanks (Given): 13
Thanks (Received): 7
Likes (Given): 28
Likes (Received): 16
33 woodie is correct, a 7 hp Tecumseh starter wil not fit or work on an 8 hp.
A 120 volt starter for a tecumseh 7 hp , is a #33328 starter , for a 8hp you need a 33329 .
Ariens 924116 10 hp 28
Ariens 924024 8 hp 32 now a 10 hp
Ariens 910008 7 hp 24
Ian Ariens 924 is offline
post #4 of 11 Old 01-01-2019, 07:18 PM
SimplicitySolid22's Avatar
Thanks (Given): 51
Thanks (Received): 59
Likes (Given): 56
Likes (Received): 90
What letter comes after 155013 or 155018??? usually a letter follows
Ex: 155013K
SimplicitySolid22 is offline
post #5 of 11 Old 01-01-2019, 07:47 PM
Thanks (Given): 51
Likes (Given): 56
Looks like Tec. starter 33329E.
Your Engine's Birthday is August 15, 1972. Built on line D.
post #6 of 11 Old 01-01-2019, 09:47 PM Thread Starter
Thanks! Im able to find a 33329A. Is there a difference?
Otterby is offline
post #7 of 11 Old 01-01-2019, 09:49 PM Thread Starter
Ex: 155013K
Ill have to look closer when I get around the machine. From the picture I have there does not appear to be a letter following the number?
Otterby is offline
post #8 of 11 Old 01-01-2019, 10:30 PM
Jackmels's Avatar
Thanks (Given): 98
Thanks (Received): 151
Likes (Received): 599
Have Used Starters Available, PM if interested.
Jackmels is online now
post #9 of 11 Old 01-01-2019, 10:48 PM
Thanks (Given): 25
Thanks (Received): 20
Likes (Given): 92
Likes (Received): 38
Otterby, where are you located? I'm in Ontario, I have a starter off a 1979 MTD. with a 8HP tecumseh, starter number is 33329C. It works and its free but the shipping probably be steep....
contender is offline
post #10 of 11 Old 01-02-2019, 05:41 AM
Thanks (Given): 7
Likes (Given): 411
NO! the letter is just the latter model of the earlier one.
ex. TECUMSEH: 33329, 33329C, 33329D, 33329E, 37000 are all the same item
132619 is offline
