Auger blades hitting impeller - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-01-2019, 12:02 PM Thread Starter
Fired up first time this year amd bang bang bang bang as soon as I engage the auger. Look and thw auger has some play, not much more than normal or first bought but the auger blades are hiti g the impeller in thw discharge chute. Bad bearings, an adjustment I can make? I'm struggling to find anyone else thats had this.
The women dont find me handsome, they dont find me handy either....
goose062 is offline
post #2 of 13 Old 01-01-2019, 01:41 PM
Thanks (Given): 88
Thanks (Received): 174
Likes (Given): 68
Likes (Received): 406
Might be the end bearings, could be an impeller bearing but go with an end bearing.
JLawrence08648 is offline
Thanks goose062 thanked for this post
post #3 of 13 Old 01-01-2019, 02:36 PM
Thanks (Given): 509
Thanks (Received): 680
Likes (Given): 3834
Likes (Received): 1474
to SBF goose062
Or the pins that hold the impeller to the shaft broke allowing the impeller to come forward.
Pull the spark plug wire off and reach in and see if the impeller will spin on the shaft.
The auger can't really move towards the impeller as it's fixed in the gearbox and the end bearings IMHO just wouldn't give it enough slack to hit the impeller.
Post Thanks / Like - 1 Thanks, 4 Likes, 0 Dislikes
Likes orangputeh, jsup, foggysail, micah68kj liked this post
post #4 of 13 Old 01-01-2019, 02:46 PM
orangputeh's Avatar
Thanks (Given): 638
Thanks (Received): 160
Likes (Given): 948
Likes (Received): 1028
thinking same as kiss4afrog. even if pin on impeller is broken it can still turn if enough rust/corrossion on shaft. otherwise there must be obvious play somewhere.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #5 of 13 Old 01-01-2019, 03:51 PM Thread Starter
update
Split it and removed the entire shaft, rakes off and split the gear housing. All the pins appear fine, worm gears (spiral one and one appears to be brass sorry still learning correct terms) look ok. But the impeller shaft turns a good 1/8th or better before it starts spinning the shaft the rakes are on. Just replace both gears I assume? Thanks for the quick replies!
goose062 is offline
post #6 of 13 Old 01-01-2019, 05:28 PM
Thanks (Given): 509
Likes (Given): 3834
Did you check to see if the impeller itself spins on the shaft ?? If the bolts or pins that hold it to the shaft are broken or sheared ??
post #7 of 13 Old 01-01-2019, 09:17 PM Thread Starter
Pin in the impeller are good. When I spin the impeller the shaft turns with it.
goose062 is offline
post #8 of 13 Old 01-02-2019, 06:23 AM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
Are the impeller tips folded out straight (forward)? I know this sounds obvious but we're starting to challenge the laws of nature.
Spectrum is offline
post #9 of 13 Old 01-02-2019, 08:15 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 56
Likes (Received): 190
A few pictures would really help to see what you are seeing.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #10 of 13 Old 01-02-2019, 09:50 AM
Likes (Given): 22
Likes (Received): 206
Seems like, since you can turn the impeller by hand, you ought to be able to watch it hit the auger - and then figure out what the issue is, right ?
Or, make a YouTube video, and we can watch it, and figure out your issue.
RIT333 is online now
