Tecumseh H60 points retrofit - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-16-2019, 09:34 PM Thread Starter
Wanting to update to breakerless ignition, any good experiance with changing over with reliability foremost. I really don't think heat is an issue with a sensible location. Problems I have read about seem to be with 2 stroke and marine conversions. Looking at Atom/blue, rotary/kawasaki single connection, rotary/nova2. Coil is under flywheel and flywheel is iron- not sure about magnets whether one or two.
ID:	151689   Click image for larger version
ID:	151691   Click image for larger version
dfarr67 is offline
post #2 of 5 Old 01-16-2019, 09:43 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
I've used the Atom years ago and I had no problems, I would expect the same with Nova, similar.
post #3 of 5 Old 01-16-2019, 09:47 PM
scrappy's Avatar
Thanks (Received): 41
Likes (Received): 94
I will tell ya what I was told 10yrs ago.
There are no "good" conversions for Tecumseh points. Only for Briggs.
If you have a clean set of points and a good condenser, it will put out reliable spark for years.
scrappy is online now
post #4 of 5 Old 01-17-2019, 11:27 AM Thread Starter
Did some work to this unit, bit of a struggle to start it- before I put any money into ignition, I wanted to know which way to jump. The Atom module states that cast iron flywheels may be an issue. BTW I have no experience with points, not a big deal but would prefer to eliminate. Going to give this a shot- their shipping is reasonable.
https://www.mfgsupply.com/smallengin...electuign.html
dfarr67 is offline
post #5 of 5 Old 01-17-2019, 02:16 PM
scrappy's Avatar
One of the things that I was told, there is no way to set the timing. With points it was easy to do with a test light and dial indicator.
Besides, point/condenser have worked for the last 52 years in my dads '67 Tecumseh.
Post up your results.
