1997 Simplicity 970M- replaced friction disc; drive stays engaged now - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 01-28-2019, 03:05 PM Thread Starter
Hi all,
New member here. Looks like a great community.
My 22-year old Simplicty SnoAway 9-70 is a champ. But it was finally time for a new friction disc (lost forward motion, little bit of snow mounding caused wheel slippage).
I popped it in last Friday. It seemed to go well, and I made the recommended owner's manual adjustments to speed selector, auger drive tension , traction drive tension.
Now, the blower seems to drive itself in anything higher than first gear, and especially with gears 4 and 5. This is without the traction control depressed. I have to shift back down to 1 or R1 R2 to get the drive to stop and go neutral.
Did I miss an adjustment?
Brian Kelley is offline
post #2 of 3 Old 01-28-2019, 07:03 PM
Thanks (Given): 16
Thanks (Received): 65
Likes (Given): 57
Likes (Received): 174
Likely you need to reduce the tension on the drive clutch cable, since it doesn't have to pull anywhere near as far to engage the drive now.
tadawson is online now
post #3 of 3 Old 01-29-2019, 09:29 AM Thread Starter
Thank you. I'll give it a try!
