Blower not throwing snow far under heavy load - help :) - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-13-2019, 05:23 PM Thread Starter
Hi everyone,
I have an Ariens Compact 24
Purchased it in 2014.
Regarlarly change the oil etc.
Update,
Took a video. Auger spins at normal speed in a few inches of snow then slows down significantly when the snow builds up within the case.
Auger belt issue?
Need replacement or tightening?
In light snow, works fine, throws snow usual distance but under heavy snow or alot of light snow, it will only throw the snow a few feet. Instead of the snow blasting out of the snowblower 20 feet in the air, it only blows out a few feet.
Could the belts need replacement?
Thanks for the help everyone
BrianOtt is offline
post #2 of 8 Old 02-13-2019, 05:25 PM
Motor City's Avatar
Thanks (Received): 44
Likes (Received): 50
Is the snow wet and heavy? If so, that will tax down most any blower. If not, you may want to check the tension on the belt. May need to adjust the cable, to have the idler pulley apply more tension to the belt, so it won't slip.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #3 of 8 Old 02-13-2019, 05:58 PM
Wes Kootenay's Avatar
Sounds like it is time to check the auger belt adjustment as shown in your user manual. Very easy job that should be checked periodically anyway.
Have fun!
Edit: As Motor City just said.
Wes Kootenay is offline
post #4 of 8 Old 02-13-2019, 06:01 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 633
If the engine is also slowing down, then you're likely just out of power, maybe due to the heavy snow.
But if the engine speed stays the same, but you don't throw as far, then a belt is probably slipping. In that case, follow the manual's instructions for setting the belt tension.
RedOctobyr is offline
post #5 of 8 Old 02-13-2019, 08:23 PM Thread Starter
Hey Motor City,
Snow was super light today
BrianOtt is offline
post #6 of 8 Old 02-13-2019, 08:50 PM
Thanks (Given): 89
Thanks (Received): 175
Likes (Given): 68
Likes (Received): 406
Need to check the rpms, may be low.
post #7 of 8 Old 02-13-2019, 09:24 PM Thread Starter
Originally Posted by BrianOtt View Post
Hi everyone,
Update,
Auger belt issue?
BrianOtt is offline
post #8 of 8 Old 02-13-2019, 09:35 PM
Thanks (Given): 118
Likes (Given): 358
Start by tightening the belt.
Similar Threads
the ideal walk behind single stage snow blower leonz General Snowblower Discussion 5 06-17-2018 06:44 AM
Finally buying a snow blower... Compact 20 or 24"? NewShockerGuy Ariens Snowblowers 21 12-23-2016 06:37 AM
Help choosing heavy duty snow blower for wet snow skdbear Snowblower Reviews 21 12-07-2016 03:04 PM
Honda HS520KAS Single Stage Snow Blower - Review steeve725 Snowblower Reviews 0 02-27-2014 04:44 PM
Sears Craftsman 536.918100 Snow Blower - Gas Leak jrijr Snowblower Repairs and Maintenance Forum 3 01-29-2014 09:15 PM
