Drive belt tensioner - is this normal? - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 29 Old 03-24-2019, 02:26 AM Thread Starter
I bought a new spring for $3.09 that cost be $4.10 to ship it or something ridiculous like that. SHould arrive tomorrow. I took it apart, inspected the pulley/bearing, cleaned everything up and nothing seemed out of place......except maybe the spring looking a bit old. Hoping this will fix it.
Is the spring supposed to go over the space piece there? Maybe that's the problem. Putting tension on the spring when installed seems way too easy. That said, it was difficult to put the belt on as I had to push the tensioner pulley quite hard.
lordoftheflies is offline
post #12 of 29 Old 03-27-2019, 06:59 PM Thread Starter
Installed the new spring....and same thing. So it is not the spring. I feel like with the tensioner pulley bouncing all over the place it's going to put extra stress on the drive belt. Then again. I wish I had taken the cover off and looked at how the old belt behaved before installing the new one.
Anyone have a similar machine that can see if their tensioner bounces around as much as mine?
post #13 of 29 Old 03-27-2019, 09:20 PM
Thanks (Given): 31
Thanks (Received): 131
Likes (Received): 226
Maybe the tensioner is positioned incorrectly? There should be a fair amount of tension on the drive belt...
tabora is online now
post #14 of 29 Old 03-27-2019, 09:22 PM Thread Starter
There's pretty much only one way and direction it can go in order for the belt and pulley to line up. Plus when I changed the belt I didn't even take off the pulley. So I highly doubt that is it.
I'm guessing now maybe there's too much tension because of the new belt? What's confusing is MTD/TroyBilt told me that correct belt is 34.4" and 3/8" top width compared to what was on the machine - 33" and 1/4" top width.
post #15 of 29 Old 03-27-2019, 09:36 PM
Thanks (Given): 31
Well, THAT'S some important information... You have not provided your actual model number; is it this one? Troy-Bilt 5024 (31AS6BN2766) - Troy-Bilt Storm 24" Snow Thrower (2006) It calls for a Troy-Bilt 954-0367 BELT 3/8 X 34.4'' But yours may be different?
post #16 of 29 Old 03-27-2019, 09:48 PM
SimplicitySolid22's Avatar
Thanks (Given): 41
Thanks (Received): 53
Likes (Given): 46
Likes (Received): 85
Haaaaaaaaaaaaa......tabora called it........How about the engine number as well.....What type of tecumseh??? 5.5hp???? LH195SP????(HSSK55)
SimplicitySolid22 is offline
post #17 of 29 Old 03-27-2019, 09:59 PM Thread Starter
31as6bn2711
Don't go by what's on the website......because it's wrong. I bought this unit brand new and the belt that was in it was 754-04088 and it's 33" x 1/4". If you look up 754-04088 on the mtd website and click on "Fits models" it shows a completely different model.....
This belt fits perfectly inside of the pulley. if it was any wider it would not fit. I've called support, chatted, and checked their websites. On the phone one rep said "If you have a 1/4" belt then get a 1/4" replacement".
Tecumseh 5.5hp.
Look at the comparison video. Same engine, same belt, same tensioner setup.....and his doesn't move at all.
post #18 of 29 Old 03-27-2019, 10:30 PM
Thanks (Given): 31
Well, looking at your video, it looks like your drive belt is too narrow for the pulley. It should not bottom in the v-groove. I would try the belt specified on all the sites I checked: 3/8 X 34.4''
post #19 of 29 Old 03-27-2019, 10:35 PM
Thanks (Given): 41
Likes (Given): 46
954-0367? So no on 3/8 X 34.4???
I typed this before tabora's posted so when I saved it I had not seen his post...disregard...
oh maybe it did not post......awww forget it...you get it. Agree with tabora....
post #20 of 29 Old 03-28-2019, 01:09 AM Thread Starter
Please explain why 754-04088 is on my machine......when purchased new..........and also on the other video I posted as well. Same machine basically, same engine, same belt.
Similar Threads
OLD NOMA 825 Track Drive BELT INFO motoman Snowblower Repairs and Maintenance Forum 0 06-05-2017 03:55 PM
Auger Idler Tension Pulley Smoking My New Belt mzblues1 Snowblower Repairs and Maintenance Forum 36 02-19-2016 06:55 AM
what's The Correct Drive Belt Tension on a SS? Golfergordy Honda Snowblowers 16 01-06-2016 06:36 PM
Simplicity 755E (#1692681) Belt Replacement af3683 Simplicity Snowblowers 4 02-28-2015 08:35 AM
HS 828 drive belt tensioner is always tense... real head-scratcher. JMM Honda Snowblowers 14 02-01-2015 01:53 AM
