Need a bit of a pros advice here: Engine noises [with a video] - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 03-23-2019, 07:19 PM Thread Starter
Need a bit of advice here: Look and listen to this machine up-and-down engine run: https://photos.app.goo.gl/YB3Ktsto9ENdn4Ky9
What did I do so far:
1. Purged the fuel, put new.
2. Added these fuel add-ons that clean the fuel system clean. twice.
3. Replaced the spark plug with a new one.
4. Disassembled the carburetor completely, cleaned it thoroughly, applied the spray that clens carburetor to wherever I could. Put the whole thing back.
Same ****. Nothing changed. Exact same sound.
Any ideas from the pros ?
avner123 is offline
post #2 of 6 Old 03-23-2019, 07:35 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 637
Welcome to the forum! What were you adjusting during the video? Is that the choke control? Or throttle?
It sounds like it's surging due to running lean. Does adding choke help smooth it out?
Is there a fuel filter? Are you getting good fuel flow to the carb? (If you disconnect the line from the carb, do you get a good stream of gas from it?)
Is anything in the governor linkage sticking or binding?
post #3 of 6 Old 03-23-2019, 08:12 PM
Likes (Given): 382
how did you clean the carb ? sounds like a classic dirty carb situation.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
nwcove is offline
post #4 of 6 Old 03-23-2019, 10:02 PM
Thanks (Given): 91
Thanks (Received): 183
Likes (Given): 70
Likes (Received): 421
Dirty carb, it may look clean but it's not, replace unless you can do a better job, the ultimate is an ultrasonic cleaner.
post #5 of 6 Old 03-23-2019, 10:56 PM
Thanks (Given): 38
Likes (Given): 35
May need to drill carb jet, to create a richer mixture . I'd also like to ask, did choking it smooth idle ? If choke smooths idle, Jet too lean . Check for vacuum leaks at carb to manifold gasket, use spray bottle and water .
Fat City is online now
post #6 of 6 Old 03-23-2019, 11:54 PM
Motor City's Avatar
Thanks (Received): 50
Likes (Received): 54
Carb is not clean enough. The carbs on those can be a challenge to get clean. Knock off carbs are pretty cheap on Ebay. On those you need to take the idle screw out and pull out the black low speed jet under it. Turn the idle screw in, counting the turns. And reinstall with the same turns of the idle screw. I also drill out the jets on those a little bit. You can get an ultrasonic cleaner at Harbor Freight, and use some Simple Green, to clean it.
Ariens ST11528LE
Honda HS720
Motor City is online now
Similar Threads
HELP - I need some advice on how to proceed - repower? Turbohvn Re-Powering 6 04-13-2015 06:02 PM
Gilson snow blower engine swap with harbor freight 6.5hp engine tbe55 Snowblower Repairs and Maintenance Forum 6 01-03-2015 04:40 PM
International Cadet 265 problems NDbrewer Snowblower Repairs and Maintenance Forum 64 02-06-2014 12:45 AM
Free Snowblower - Engine won't start...Help! floor61 Snowblower Repairs and Maintenance Forum 41 01-29-2014 05:25 PM
B&S V-Twin Engine Swap grupe Snowblower Repairs and Maintenance Forum 25 01-29-2014 10:55 AM
