Differential identification, help needed - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 09-09-2019, 09:12 PM Thread Starter
Hello all, my first post here. I have a tractor snow thrower that is broken. The differential isn’t working anymore. At first I was thinking it was custom built using an old dodge differential or something similar but I haven’t been able to make a link with any model from the picture that I found on the net. I’ ll unmount the thing over the weekend in order to open iy
https://imgur.com/a/DQYiFCy
Tommy Blackburn is offline
post #2 of 3 Old 09-10-2019, 12:34 AM
leonz's Avatar
Thanks (Received): 89
Likes (Given): 76
Likes (Received): 158
Welcome to the forum Tommy,
You may want to wander over to the www.mytractorforum.com web page and become a member and also post your pictures there too.
leonz is offline
post #3 of 3 Old 09-10-2019, 02:36 AM
ST1100A's Avatar
Thanks (Received): 78
Likes (Given): 143
Likes (Received): 101
What is the manufacturer of that machine? It could be a unit built by them or an old Eaton or Ford unit. Most of the Dana/Spicer units had a removable ring gear cover. Your unit has the removable ring and pinion gear carrier "Center section" that is removed while it is still installed in its holder. I have seen many differential/final drive, bevel gear cases like that from years ago, it was just a ring and pinion set-up for a snowblower with no spider gears in the ring gear carrier case. Some old carnival rides used that gear case a long time ago. They were built by the manufacturer of the machine that it was used for back then, it was a simple design back then. Some old Ramblers used a set-up like that.
I wonder if that was a home made or custom made unit, it is hard to tell without knowing who it is manufactured by.
ST1100A is offline
