Removing Gas out of the Generator - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 10-02-2019, 01:08 PM Thread Starter
Thanks (Received): 33
Likes (Received): 54
don't wanna spring the big - bux for a small battery operated pump but it looks like I might....
Honda EU portable generator.
Looking to drain the fuel tank.
This thing must have a small pump on it, as gravity draining is not doing a thing.
Just short of plugging something into it and running the generator.....or buying a small pump to evacuate the fuel out of the tank, and weekend warrior tips on a DIY option on draining the fuel tank out of this thing
mobiledynamics is online now
post #2 of 6 Old 10-02-2019, 02:17 PM
ST1100A's Avatar
Thanks (Given): 134
Thanks (Received): 115
Likes (Given): 245
Likes (Received): 197
Get a siphon, hand pump type, put a piece of hose on it if you have to. Pump out as much gas as you can, or tip it over and dump out the gas.
Then start it and let it run until it empties itself out all the way.
Then when all that is done, loosen the little drain bolt on the carb bowl and drain the rest of the gas out there, and you should be finished.
ST1100A is offline
post #3 of 6 Old 10-02-2019, 02:45 PM
Thanks (Received): 204
Likes (Received): 745
Like ST1100A said
cranman is offline
post #4 of 6 Old 10-02-2019, 02:55 PM
tdipaul's Avatar
Thanks (Given): 79
Thanks (Received): 81
Likes (Given): 315
Likes (Received): 342
always wanted one of those EU's, the Big One.
Honda at its best
but havent needed generator since Sandy in 2012
hard to justify
1989 John Deere 1032
tdipaul is online now
post #5 of 6 Old 10-02-2019, 04:40 PM
Miles's Avatar
Thanks (Given): 80
Thanks (Received): 59
Likes (Given): 325
Likes (Received): 168
I got this one on Amazon: Plumber’s Siphon Pro - Gas, Oil, Water - Up to 3.5 Gl. Per Min. ONLY Siphon With Multi-size Tip Designed to Fit Any Hose. Comes with 9 ft. Hose. Brass Tip Weight and Extender – See Video in Pictures
Honda HSS928AWD (upgraded chute, transmission)
Honda HS720AS (at sister's)
Honda EU2000i (generator)
Miles is online now
post #6 of 6 Old 10-04-2019, 11:43 PM
enigma-2's Avatar
Likes (Received): 48
Think this is what you're looking for. All you need is a screwdriver. Drain gas starts around 2:20
https://youtu.be/8SBsNhuqFKY
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
