craftsman 247.889571 Won’t move - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 10-11-2019, 06:19 PM Thread Starter
I have a craftsman 247.889571 24” snowblower that won’t move. When I press throttle lever it jerks slightly but then stops. I took off cover on bottom to see what was going on. When I press throttle lever it raises friction plate up to wheel that makes tires spin but then the friction plate and drive belt just completely stop as if something too tight. Any suggestions on what I might need to look at?
Dctiff2 is offline
post #2 of 10 Old 10-11-2019, 06:25 PM
Jackmels's Avatar
Thanks (Given): 108
Thanks (Received): 164
Likes (Given): 347
Likes (Received): 645
Try Changing the Speed. You could be at "Center" of drive plate
Jackmels is offline
post #3 of 10 Old 10-11-2019, 06:27 PM Thread Starter
The speed changes and moves wheel to different part of friction plate as it should
Dctiff2 is offline
post #4 of 10 Old 10-11-2019, 06:41 PM
Jackmels's Avatar
Thanks (Given): 108
Likes (Given): 347
Check the Drive Belt Tension, might be loose
Jackmels is offline
post #5 of 10 Old 10-11-2019, 06:43 PM
malisha1's Avatar
Likes (Received): 29
Prolly oil or grease on the friction disc or plate
malisha1 is online now
post #6 of 10 Old 10-11-2019, 06:49 PM Thread Starter
The belt is tight so think it’s good. I will try cleaning out grease. It seems like friction plate just raises to high so it completely stops it from moving. I appreciate the suggestions I have received so far.
Dctiff2 is offline
post #7 of 10 Old 10-11-2019, 06:50 PM
Jackmels's Avatar
Thanks (Given): 108
Likes (Given): 347
Loosen the Cable that Pulls the Drive plate in. Can you spin the wheels by hand?
Jackmels is offline
post #8 of 10 Old 10-11-2019, 06:57 PM Thread Starter
It spins but is tough to turn so requires a little effort
Dctiff2 is offline
post #9 of 10 Old 10-11-2019, 07:11 PM
oneacer's Avatar
Thanks (Received): 48
Likes (Received): 138
Looks like a good inspection of the order of operation is needed. Watch also for broke or missing springs, as well as anything out of place or bent.
Usually a good, careful inspection will give you your answer.
oneacer is online now
post #10 of 10 Old 10-11-2019, 08:15 PM Thread Starter
Ok thanks, I haven’t found anything obvious. Will keep searching
Dctiff2 is offline
