Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools |
Noma/Murray E2784-000 code 4236 operators manual/grease recommendations
Hello,
I have an older Murray snowblower with an 8hp Tecumseh engine. It runs great with some work, and have been able to find some parts and the manuals for the engine but have been unable to find any documentation on the blower itself. Also trying to maintenance the machine and am looking for what type of greases to use as well as other maint. specifics. Can anybody help?
Thank you
Thank you
Sponsored Links | |||
Advertisement |
Thinking of using Trophy
EP White Lithium Low Temp Grease (specs
http://www.comolube.com/wp-content/u...te-Lithium.pdf
Any thoughts?
Any thoughts?
Seems the general rule hear is in the cast iron gearboxes, most use a gear lube oil, and in the clamshell aluminum gear boxes, most use a grease, with many using "00". A lot even use that in the cast boxes with leaking seals.
Originally Posted by oneacer
View Post
I was speaking more about general lubrication; augers and other zerks, etc. Don’t think it’s been done before, at least since it’s been in the family. Was given to my parents from old neighbors years ago, and I am doing some much needed maintenance.
Seems most here have there favorites. I personally am a fan of the red grease, also white lithium.
Also a big fan of the chain and cable lube called MAC, from NAPA.
And I am always using Trizol for a penetrating lube.
Also note, all my small equipment only uses the 5W30 Full Synthetic motor oil … summer and winter equipment
@oneacer Thanks, going to try the low temp white.
Update: Just put a new float bowl on, drain disappeared from the last. I put new float needle, bowl, and seat like 6 years ago and family have been using it basically since so going over it all.
Gas is dripping from the carburetor out of the choke now, Anyone have any thoughts as to why this is? And would I have to put a new o ring on the bowl if I have to take it back off? Been on for maybe two days. Engine is Tecumseh HMSK80 155480s (D)
I wonder if your new float needle is the correct one? Could be it is not seated correctly against the small rubber seat in the carb, allowing gas to continually flow out? Or, is the float set correctly?
Originally Posted by gsnod
View Post
However I just realized I’ve pulled on the starter cord a few times with the throttle closed to rotate the augers, could this have pushed gas up and out?
Originally Posted by djames187
View Post
If that is true then it follows that the machinery will be very happy with any grease since that is most assuredly better than none.
View Post
Ariens 1027le
Meyer 8' Stainless Lot Pro fitted to 2012 F250
17 Arctic Cat Mtn Cat, for the day after
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Posting Rules | |
