Snowblower kill switch part identity - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 11-23-2019, 04:19 PM Thread Starter
Hello all,
Does anyone know what this part is called(not my machine as this is from a YT video)? It is the connector from the key wire to the kill switch that resembles a metal boomerang from my ancient snowblower. Mine has broken in half due to metal fatigue. The metal connector part is what I need to replace on my machine. Mine has a wire with a female spade connector to the key that attaches to a ground plate(I'm guessing) & from there to this dual spade male connector & then to the kill switch. It is from a circa 1980 Noma snowblower with a Tecumseh engine.
Secondly, can I buy just this part or will I be forced to get the whole wiring assembly? Would there be a way to McGyver this connection instead?
Also I did a carb clean and overhaul. Since them the engine does not seem to respond to the throttle well any more. Not sure if I have the linkages in the right configuration or if something is sticking or if this is caused by the kill switch not working. Currently I cannot turn the blower off unless I shut the fuel valve.
TIA
Name:	blower kill switch.JPG
bluegirl is offline
post #2 of 7 Old 11-23-2019, 04:28 PM
oneacer's Avatar
Thanks (Received): 147
Likes (Received): 538
The shut off issue is definitely due to the grounding kill switch being broken. If you have an electrical crimp kit, there should be something to repair that with. If not, a local hardware or automotive store should help you out. Bring the old one with you.
I keep all connections, nuts and bolts from anything I discard for this exact reason. I have drawers of connectors, switches, bolts, nuts, etc., etc.....
If your not getting response from the throttle, maybe first try repositioning it from under the outer sheave cable clamp, or even putting it in another linkage hole possibly. ???
oneacer is offline
post #3 of 7 Old 11-30-2019, 04:44 PM Thread Starter
Here are a few pictures of my carb and kill switch. I can't figure out where I have gone wrong with regards to the throttle not responding. It did before I took it apart. Is the linkage in the incorrect hole? The throttle cable seems stable. The kill switch still needs the key wire attached, but I don't think I need that in order for it to run. I was able to McGyver the old kill switch with a new spade connector connected to the wire, I'm not sure if the current is perceptible. Is it possible to test it if works or not?
ID:	160001   Click image for larger version
ID:	160003   Click image for larger version
bluegirl is offline
post #4 of 7 Old 12-11-2019, 09:26 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
The "hole" next to the hole that the linkage is in, is that a hole or a rivet? If that is a hole, put the linkage in that hole.
You should replace the plastic gas line with black fiber reinforced gas line. It's next to the muffler and will melt too easily.
post #5 of 7 Old 12-11-2019, 10:13 AM Thread Starter
"Next to the hole" to the right or down? Thanks for your help.
bluegirl is offline
post #6 of 7 Old 12-11-2019, 10:13 AM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3326
Likes (Received): 677
The piece with the wire is called a shorting clip and when the throttle is pulled to off, the lever makes contact with it and stops spark. Do you have spark with the throttle on full and no spark when in off position?
Shorting clip-
https://www.ebay.com/itm/Genuine-Tecumseh-TERMINAL-Part-610973/272965564114?epid=1258873710&hash=item3f8e03f6d2:g :tV8AAOSwke9aItRS
Tecumseh series 3-
https://outdoorpowerinfo.com/repairs/tecumseh_carb_632334a.asp
Tecumseh series 1-
https://outdoorpowerinfo.com/repairs/tecumseh_carb_632107.asp
post #7 of 7 Old 12-11-2019, 11:32 AM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Donyboy73 has a video with the throttle linkage positions:
db130 is offline
