Tecumseh Starter - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-23-2019, 04:58 PM Thread Starter
Thanks (Received): 8
Likes (Received): 31
Tecumseh Starter
I checked a snowking starter for a friend and he says it just spins. I thought the bendix was dirty,stuck. But NO the starter spins BACKWARDS the bendix if set out draws back in. If someone reversed the 2 power wires to the brush plate would that do it??. I compared it to a starter I was servicing on my blower and yes it spins opposite.
gregg is offline
post #2 of 5 Old 11-23-2019, 05:05 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Yes, reversing leads on a DC motor will reverse the direction of rotation.
If AC, then no . . .
Might even be as simple as the battery being hooked up backwards . . . (if it has one).
tadawson is offline
post #3 of 5 Old 11-23-2019, 05:15 PM Thread Starter
I should have mentioned it is 120 volts AC.
gregg is offline
post #4 of 5 Old 11-23-2019, 08:09 PM
Thanks (Received): 32
Likes (Given): 46
Likes (Received): 52
As tadawson stated, reversing the power input leads on an AC motor will not change it's direction.
But, if the starter motor is series-wound (the field windings and the rotor windings are connected in series) then I believe that internally swapping the field or rotor lead connections (only one, not both) will cause the motor to run in the opposite direction. So, gregg, I think you are correct that reversing the 2 power wires to the brush plate would cause the motor to reverse direction. I have opened several of these types of starter motors for repair but I have not inspected the wiring arrangement to determine if they are in fact series-wound, but I think they probably are.
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
post #5 of 5 Old 11-23-2019, 08:41 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
5hp Tecumseh starters work differently than 6hp and up. 5hp the bendix moves towards the starter motor, 6 and up it moves away from it.
Jackmels is offline
