Tecumseh Starter - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 11-26-2019, 06:35 PM Thread Starter
Thanks (Received): 8
Likes (Received): 31
Tecumseh Starter
Anyone have any tips on assembling the brushes, all 4 at the same time. I had an extra set of hands from my wife.
gregg is offline
post #2 of 6 Old 11-26-2019, 08:46 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
I've never taken a Tecumseh starter apart but have on auto starters. For those you have to pull the brushes out to fit over the armature shaft. I always cut pieces from a metal clothes hanger and bent the end to make a hook.
post #3 of 6 Old 11-26-2019, 09:30 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I use lock wire to hold the brushes back. After you get it back together, snip the lock wires.
Jackmels is online now
post #4 of 6 Old 11-27-2019, 08:32 AM
Likes (Received): 17
Hold them apart with a plastic cork, a dowel or similar that is slightly larger than the rotor. Using a matchstick or something, wet all four brushes with drops of water, them chuck it all in the deep freezer. Check after half an hour, add water if necessary. When all brushes stick, assemble and let thaw. Works like a charm.
__________________________________________________ _____________
Eastern Norway, -25 degree winters, +30 summers (some years ...)
1990 Toro 824 Powershift
Unknown year Partner 5-61/HM50, for sale
Norwegian is offline
Likes Grunt liked this post
post #5 of 6 Old 11-27-2019, 03:23 PM
Thanks (Received): 99
Likes (Given): 741
Likes (Received): 263
there was a tool to hold the brushes out, don't know where anyone would find it today with tech gone for how many years
87powershiftx2 is offline
post #6 of 6 Old 02-01-2020, 10:20 AM Thread Starter
Found this on youtube...
gregg is offline
