MTD impeller shaft bearing removal - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 11-27-2019, 12:17 PM Thread Starter
I am trying to remove the impeller shaft and it seems to be stuck in the bearing. Is there a trick to getting it off?
dirtrider180 is offline
post #2 of 8 Old 11-27-2019, 12:29 PM
oneacer's Avatar
Thanks (Received): 149
Likes (Received): 540
From just looking at the picture, without being there in person, I would spray some Trizol on it where the bearing is against the housing, or any weasel piss, and put the bolt back in tight, so not to mushroom the end, and tap it out of the case housing.
Amazing you got the augers and the gear box apart while it is still in the housing. That is usually done when its out of the housing, just for simplicity.
oneacer is online now
post #3 of 8 Old 11-27-2019, 12:48 PM
SimplicitySolid22's Avatar
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
Do exactly what Acer said and add a block of wood behind that bolt then several decent Love taps to boot!!!!
SimplicitySolid22 is offline
post #4 of 8 Old 11-27-2019, 12:49 PM
Thanks (Given): 63
Likes (Given): 77
I found this from last season:
See 3:52 to 7:48
post #5 of 8 Old 11-27-2019, 12:50 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Or a block of wood and 5lb sledgehammer.... couple of Love taps on the bearing side and it should pop right out.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #6 of 8 Old 11-27-2019, 12:54 PM Thread Starter
I tried doing that and it doesn't seem to be moving at all. I was hitting it pretty hard.
post #7 of 8 Old 11-27-2019, 01:29 PM
Thanks (Received): 22
Likes (Received): 38
That bearing is shot anyway. Get some heat on the inner race just before the shaft to break the rust bond, then hit hard.
all3939 is offline
post #8 of 8 Old 11-27-2019, 01:39 PM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
to SBF dirtrider180
If you haven't yet, it might be time to accept the bearing is going to need to be replaced and use lots of heat on it and try the hammer again.
Just saw it was suggested
