snowbower wont stay running - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 11-29-2019, 03:21 PM Thread Starter
I have a 2004 snapper snowblower with a Tecumseh 7 hp engine that wont stay running.i'll star it and it will run for about 4-6 minutes then stall. It will start right back up butnonly run for 3 seconds. i can do this several times. then it will run for the 4-6 minutes and then stall. i can do this routine several times and then finally it wont start at all. I have replaced the carburater and all fuel lines.
aralou is offline
post #2 of 8 Old 11-29-2019, 03:33 PM
71Dragtruck's Avatar
Thanks (Given): 8
Likes (Given): 12
Likes (Received): 23
Wonder it it’s something with the ignition or a ground wire for the on/off that once it gets hot it craps out, once it cools back down I take it you can do it all over again?
Honda HSM1336i
Yamaha YS-624
Honda HS720CS
71Dragtruck is offline
post #3 of 8 Old 11-29-2019, 04:04 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
Try loosing the gas cap, and see if it stays running. I would also check for spark, with the spark plug, although it sounds like it fires back up. Also the fuel line could be old and rotted, causing fuel starvation. Do you run it dry at the end of the season?
Ariens ST11528LE
Honda HS720
Motor City is offline
post #4 of 8 Old 11-29-2019, 04:08 PM
Likes (Received): 9
I had a Tecumseh 8 hp that did the same thing, It turned out to be a bad spark plug.
MSB1766 is offline
post #5 of 8 Old 11-29-2019, 04:26 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
bad gas cap, fuel shutoff, coil and/or its wiring, spark-plug and/or its boot.
also check compression
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #6 of 8 Old 11-29-2019, 06:10 PM
Thanks (Given): 26
Likes (Given): 85
Crap in the floatbowl can also do this, and not uncommon from an old fuel line breaking down. Particles slowly get pulled into the orifices, and it dies, and after it is drug back, sloshed, sworn at, as well as elapsed time, will repeat. Other issues are more common, but definitely had this in a 7HP Tec 2 years ago. Had almost dustlike black crap intbe carb from the line,no matter how many times I cleaned it. One new fuel line, bowl clean, and tank rinse later, and perfect for 2 years!
tadawson is offline
post #7 of 8 Old 11-29-2019, 10:51 PM
Likes (Received): 62
How old is your fuel?
CO Snow is online now
post #8 of 8 Old 11-29-2019, 11:56 PM
ST1100A's Avatar
Thanks (Given): 201
Thanks (Received): 126
Likes (Given): 413
Likes (Received): 266
Check your intake and exhaust valve clearance. The problem you are having is very common with either ignition coil not firing when it gets hot and also when the valve clearance is tight, and when they get hot, the stem expands and they will not close all the way to seal up the combustion chamber, causing lack of compression or "Spit-Back" through the intake system.
On the ignition coil, when they get hot, the windings in the coil expand and creates an "Open" in the coil windings, and No Spark.
Once everything cools down the coil might fire again and valves will seal again due to contraction.
Check those items if all else checks out ok.
ST1100A is offline
