Tec HS50 and Nova 2 - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-30-2019, 05:10 PM Thread Starter
Tec HS50 and Nova 2
Hi all. I know this is probably beat to death, but I've been researching to no avail. I have a mtd snow blower with a tec hs50. I went to start it up and there was no spark so I opted to replace it with a nova 2. I dont know where I'm going wrong. I disconnected the kill switch because I have no key anyway. I attached a couple pics to show my temp setup. I was checking for spark by turning the crank with a ratchet. I tried reversing the polarity, and the second little wire off the coil I tried connected and disconnected. it used to be attached to where the condenser was screwed in.
ID:	160009   Click image for larger version
RJK81 is offline
post #2 of 5 Old 11-30-2019, 05:23 PM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1028
Here ya go.
I think you probably can't get it to turn fast enough with a ratchet spin. Put it back together and pull the rope.
I'm going to ask a stupid question... You did have the flywheel on when you tried it?
post #3 of 5 Old 11-30-2019, 05:33 PM
Thanks (Given): 172
Likes (Given): 450
one more...
Name:	Nova ll ignitor wiring.PNG
post #4 of 5 Old 11-30-2019, 06:22 PM
scrappy's Avatar
Thanks (Received): 41
Likes (Received): 98
Maybe the coil is kaput, and that is the original problem.
Points/condenser work just fine in Tecumseh's. With the module you have no way to set actual ignition timing.
All of mine are running points. They fire up on 1 or 2 pulls.
Some useful tips here.
https://www.oldminibikes.com/forum/i...od-read.55784/
scrappy is offline
post #5 of 5 Old 11-30-2019, 06:41 PM Thread Starter
Lol yes I had the flywheel on. That second short wire off the coil is just a ground I assume?
RJK81 is offline
