Troy-bilt Storm 2860 wont start - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-02-2019, 06:16 PM Thread Starter
Hello, all
First let me point out I know nothing about engines.
My dad bought a Storm 2860 about three years ago. He got it to work the first year, but nothing since
A friend is trying to get it started now. He's verified that the spark plug sparks. He's put in fresh fuel.
What he can't find is the air filter!
The manual is useless. The cover shows 3 different engines, but the instructions lump them all together. Is there an air filter for the 243 Cc engine, and if so where is it? (He's thinking of spraying it with starter fluid.)
Or would just spraying starter fluid where the spark plug used to be (if he takes it out) worthwhile?
frustratedsnow is offline
post #2 of 8 Old 12-02-2019, 06:20 PM
Thanks (Received): 212
Likes (Received): 767
no air filter.....I would check spark with a spark tester....or lacking that ,take the carb shroud off and spray ether or carb cleaner into the throat of the carb to see if it fires....if it does, spark is good, and you need to replace or clean the carb
cranman is offline
post #3 of 8 Old 12-02-2019, 06:29 PM Thread Starter
Hi,
Thanks for your quick response.
The snowblower started when he sprayed starting fluid into the spark plug thingy.... and ran for a few seconds...
But apparently it isn't drawing fuel, even though he's filled it up with fresh fuel.
Any idea what could be causing that?
post #4 of 8 Old 12-02-2019, 06:43 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
Sounds like . . .gummed up carburetor. Fairly common. I usually run a highly concentrated mix of carb/injector cleaner for the first tank of the season.
You might have to take the carburetor off, or at least remove the bowl and spray some starting fluid in there to loosen the old fuel up.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #5 of 8 Old 12-02-2019, 06:45 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
Originally Posted by frustratedsnow View Post
Hi,
As stated above, the carb needs to be cleaned. Did you leave gas in it over the summer. You need to run it dry at the end of the season.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #6 of 8 Old 12-02-2019, 06:49 PM
Thanks (Received): 11
Likes (Given): 28
Likes (Received): 32
Hi,
Silly question.. But does it have a fuel shut off and if it does.. Did he turn it back on? Otherwise I would guess carb needs cleaning, or a blockage in the fuel line.
2muchsnow is offline
post #7 of 8 Old 12-02-2019, 06:50 PM Thread Starter
Thanks!
My friend has given up for the night, he will try that tomorrow.
Thanks for being so kind and answering a newbie's questions!
post #8 of 8 Old 12-02-2019, 07:11 PM
Thanks (Received): 150
Likes (Received): 543
If it was mine:
I would first take the fuel line off the carb, with a funneled jug to drain the gas.
I would pull the carb, being careful to mark the holes (or photo) and not bend anything or stretch any spring.
Clean the carb thoroughly, and make sure the needle is seating properly.
Reassemble the carb, and would be a good time to cut in a shut off beneath the tank if you does not have one.
If the carb is bad, replacements are 12-15.00 on Amazon.
And always , for any gas you get for your equipment, (as myself, I use 4 - 5gallon cans,) and immediately add Stabil and half the recommended amount of SeaFoam into each can. Never have I had a gas issue in any of my equipment, new or old, summer or winter, including my generator, pressure washers, blowers, mowers, etc......
oneacer is online now
