Old Ariens 924038 engine issue. - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 12-03-2019, 07:24 PM Thread Starter
Likes (Received): 8
My old 7hp Tec. Snow King has developed an issue of loosing spark once the engine is heated up from normal operation. Let it cool off and spark will be back and engine will run untill it warms up again. I can duplicate this repeatedly. I thought I heard that this could be a sign of a bad coil. I replaced the original points and condensor about 5 years ago if that means anything.
dcinma is offline
post #2 of 10 Old 12-03-2019, 08:19 PM
Ian Ariens 924's Avatar
Thanks (Given): 20
Likes (Given): 48
Likes (Received): 23
Replace the coil, they go bad.
You mentioned once warm it dies, let it cool it goes again.
Its the coil
Ariens 924024 8 hp 32 now a 10 hp
Ariens 910008 7 hp 24
Ian Ariens 924 is offline
post #3 of 10 Old 12-03-2019, 08:23 PM
Thanks (Received): 32
Likes (Given): 45
Likes (Received): 52
Yes, it is most likely a bad coil. But it might be a bad condenser. I would replace both. And look at the points while you are in there.
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
post #4 of 10 Old 12-03-2019, 08:35 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2040
Likes (Received): 517
I've had that same symptom on an H70 and it was pitted points (link). Swapped the points and set the proper spark advance (0.080" B.T.D.C.) and she's been running smooooth ever since.
('87 Toro 38150 826)
post #5 of 10 Old 12-05-2019, 11:16 AM Thread Starter
Likes (Received): 8
I just ordered a new coil, points and condenser. I'll try the coil first.
Someone mentioned the condenser, why can a condenser fail hot, work cold like coils are known to do?
dcinma is offline
post #6 of 10 Old 12-05-2019, 01:15 PM
Likes (Given): 45
It's the same mechanism in coils, condensers, or other electrical parts. Heat causes expansion in the internal parts of the component. The expansion can cause a circuit to open or to short circuit. When a component cools the fault can disappear. Old parts subject to vibration are prone to this type of failure. A new part can also experience this type of failure if there is a manufacturing defect. An intermittent fault can continue indefinitely, can become permanent at any time or disappear and not recur. Intermittents can drive you crazy. That's why sometimes it's best to shotgun it and replace everything that might be causing the problem.
1997 Toro 724
post #7 of 10 Old 12-05-2019, 03:24 PM
Thanks (Given): 231
Likes (Given): 2040
make sure you mark the magneto position before removing to replace the coil; the magneto's rotation (along with the points gap) determines the spark advance.
Thanks eyebolt thanked for this post
Likes Grunt liked this post
post #8 of 10 Old 12-08-2019, 02:07 PM Thread Starter
Likes (Received): 8
Still waiting on the parts. I think I'll shotgun everything to be sure.
I did time the engine the last time I replaced the points and condensor. I kind of forget how I did it. I didn't the Tecumseh tool. I pulled the head and somehow set it up to specs and it ran great for the last 5 or 6 years untill now. I think I put a machinests rule across the deck and used a shim of the correct thickness.
dcinma is offline
post #9 of 10 Old 12-08-2019, 02:32 PM
malisha1's Avatar
Likes (Received): 32
Please take pictures. I have the same machine.
malisha1 is offline
post #10 of 10 Old 12-26-2019, 10:07 AM Thread Starter
Likes (Received): 8
Well it's all done and came out well. I kind of jumped ship and posted a question about the BTDC setting on a new thread and rest of the info is there. Hope it wasn't a violation of forum rules. Just look for my thread "Tecumseh BTDC clearance setting".
I did take some pictures don't know if they will help you, what are you specifically interested and maybe I can help.
dcinma is offline
